Activity › Forums › Apple Final Cut Pro Legacy › OOPS….. Editing a 720p project… now client wants SD instead… Help?
Jeremy Garchow replied 18 years, 10 months ago 6 Members · 26 Replies
Bret Williams
November 20, 2007 at 3:38 amI’ve never heard of this. Are you sure? I always assumed pan and scan just meant that was the process that made it 4:3. Somebody “pan and scanned” it.
Jeremy Garchow
November 20, 2007 at 3:49 amIt happens during encoding, and it’s not something that Compressor/FCP can do. Here’s a link to software that will add the information to the MPEG-2 stream as proof of concept.
https://www.pixeltools.com/tech_tip_cablelabs.html
Someone does pan and scan it, but this way, they encode one movie for both 16×9 and 4×3 monitors without a letterbox on 4x3s.
I have not been able to track down much info on this, so everything I know is from my limited internet research. It seems to happen only on super high end encoding/authoring systems.
Jeremy
Walter Biscardi
November 20, 2007 at 10:54 am[JeremyG] “I have not been able to track down much info on this, so everything I know is from my limited internet research. It seems to happen only on super high end encoding/authoring systems.”
You can also do pan and scan using Color. It’s a manual process, but you can perform the procedure there as well.
And yes, Pan and Scan is exactly what Jeremy describes, you’re able to pan and scan the 16:9 image into a 4:3 frame and move the framing accordingly.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Matthew Abourezk
November 20, 2007 at 3:36 pmThanks all for the responses…..
One final round of questions then in regard to editing in HD and finishing (DVD) in SD.
This is something I could learn with experimenting but for the sake of my schedule, I will ask….HD and SD are totally different height and width ratios. What is going to happen when I import my HD ref movie into DVDSP? Black bars at top and bottom? Everyone going to be short and fat?
And finally, if I stay within the safety zones in HD, will I be good to go when I change everything to SD?
Thanks again…
Talkingbox Digital Media Group, Inc.
http://www.talkingboxdmg.com
(203) 327-6617 -
Walter Biscardi
November 20, 2007 at 3:41 pm[mabou2] “HD and SD are totally different height and width ratios. What is going to happen when I import my HD ref movie into DVDSP? Black bars at top and bottom? Everyone going to be short and fat?”
If you set it up as a 16:9 widescreen DVD, it will be letterboxed.
[mabou2] “And finally, if I stay within the safety zones in HD, will I be good to go when I change everything to SD?”
If you stay in letterbox, yes.
If you require the project to be 4:3 centerpunched, I’m almost certain Compressor can do this as well when you make the MPEG-2 movies. I’ve not had to do this, but I’m pretty certain you can do this.
Jeremy Garchow
November 20, 2007 at 5:13 pm[walter biscardi] “You can also do pan and scan using Color. It’s a manual process, but you can perform the procedure there as well. “
Then can you export the pan and scan database and put it into DVDSP?
You can do a manual pan and scan in FCP too, but the probelm is that you will have a 4×3 movie. A real pan and scan would allow the enocidng of one anamirphic movie and have it play full frame on either 4×3 OR 16×9 monitors.
Pretty sweet. And you say Color can do this?
