Activity Forums Adobe Premiere Pro NVIDIA GTX 285 Mercury playback
  • Walter Soyka
    December 10, 2013 at 1:31 am
    [Wendell Davis] “Thanks Walter – actually considering moving backwards to 10.8. Happy Holidays!”
    Good luck and I hope it resolves your issue.
    Cheers,
    Walter Soyka
  • Peter Mackay
    December 10, 2013 at 1:59 am
    Walter I do have that Cuda driver installed. Here is what I get when clicking on the nVidea driver in System Preferences:
    It seems that the nVidea web driver is not working with Mavericks and that breaks Cuda.
  • Peter Garaway
    December 10, 2013 at 5:10 pm
    I will note that even though the Quadro 4000 is not listed as officially supported it appears to work fine on Mavericks.
    Older cards such as the GTX 285 and Quadro 4800 will not work with Mavericks.
    Going back to 10.8.x or upgrading to Quadro 4000, K5000 or GTX 680 would be your best bet.
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
  • Peter Mackay
    December 10, 2013 at 5:45 pm
    Thanks for the reply Peter, but I can assure you that the Quadro4000 is not working here. I have just ordered a GTX 680 to replace it.
  • Peter Garaway
    December 10, 2013 at 5:56 pm
    Hi Peter,
    Well your probably enjoy the performance boost with the 680 anyway but I wanted to let you know I’m successfully using the Quadro 4000 on Mavericks with the following driver:
    https://www.nvidia.com/object/macosx-cuda-5.5.28-driver.html
    You can also try installing this but it should not make a difference:
    https://www.nvidia.com/download/driverResults.aspx/68439/en-us
    Peter Garaway
    Adobe
    Premiere Pro
  • Peter Mackay
    December 10, 2013 at 6:10 pm
    Peter see below this is what I get when trying to install the driver that you referenced in your post, I would appreciate any suggestions that you may have.
Page 2 of 2
