Activity › Forums › Adobe After Effects Expressions › number counter
Liran Tabib
April 22, 2016 at 6:53 amA new Tool to solve this old problem.
I created a Counter Preset to create any Counter and running numbers animation. I hope you will find it useful. you can get it here:
https://www.vdodna.com/products/counter-preset/ -
Jim Darski
May 12, 2017 at 1:25 amHi Dan,
Is there any way to mix different font size and color? It seems they do not carry over from the original text.
Jim -
Dan Ebberts
May 12, 2017 at 3:36 amUnfortunately, everything gets the same formatting as the first character. You could a Fill Color Animator, but that doesn’t help you with font size. If it’s important, you’ll probably need to use separate text layers and use sourceRectAtTime() to position the pieces horizontally.
Dan
Quentin Guestin
May 12, 2017 at 3:39 pmThere is a free preset on a french forum :
https://motion-cafe.com/preset-counterproIt’s based on the Dan’s expressions. It’s very useful !
Lara Malas
March 16, 2020 at 4:37 pmHow can I add a zero before the number? so it goes 01-02-03 etc? I’m trying to make a clock ticker go up
