Activity Forums AJA Video Systems NTSC SD Out From Kona 2
  • Jim Tuchschmidt
    January 16, 2006 at 3:44 pm
    Appreciate the help. I have the green cable connected to the monitor and the analog output set to composite+YC. The frame rate and the output are both set to SD and all I am trying to output to the monitor is a default signal generated by the Kona Control Panel’s “Control” menu. Will call AJA after the holiday. Thanks again, Jim
Page 2 of 2
