Activity › Forums › Maxon Cinema 4D › Nota 1.2 Released
Nota 1.2 Released
Posted by Renatot on April 6, 2005 at 4:29 amHi all,
just now i released a Nota1.2.
I sent the mail to all Nota users so if you don’t get it .. write to me SmileThanks all
Renato T.
http://www.tarabella.it/c4dRenatot replied 21 years, 5 months ago 4 Members · 15 Replies -
Dave Tavernier
April 6, 2005 at 4:37 pmI have the NOTA plugin installed with key. The sample scene in the NOTA folder works BUT WHEN I SET UP A NEW SCENE THE PLUGIN DOES NOT WORK! I have everything set up just like the sample scene. Help!
Ingemar Björling
April 6, 2005 at 6:05 pmDoesnt Nota show up or cant you select it or what is the issue?
Renatot
April 6, 2005 at 9:21 pmHI all,
I suggest to you to see videos on https://www.tarabella.it/c4d/nota/
you must download a free codec Divx from: https://www.divx.com/divx/download/
The probs is that nota check for keyframes set on a group of object.
So no keyframes, no animation or you’ll loose all position for objects.Please take a look on first video.
Cheers
Renato T. -
Dave Tavernier
April 7, 2005 at 2:32 pmOK,
I went through the steps and yes the text responds to NOTA but the problem is…..the text only responds as a block of text! What do I need to adjust to get the text to break apart????? Yes, I viewed the online tutorial but there is NO AUDIO on the tute and the INTERFACE SHOWN ON THE TUTE IS NOT THE SAME INTERFACE I SEE ON MY MONITOR?! This is very frustrating, it looks like NOTA has possibilities but how am I supposed to learn to use it with NO CLEAR DOCUMENTATION????? Again, how do you break the text apart in version 1.2???
Thanks -
Renatot
April 7, 2005 at 3:37 pmHi,
to break all letters from a text you must set the SEPARATE LETTERS on text then MAKE EDITABLE.
No you must have a null with all letters like curve inside.Add extrude nurbs and drag the Null inside then enable Hierarchical in extrude then MAKE EDITABLE.
You must have a NULLA named EXTRUDE NURBS, Null Called TEXT and at last, a NULL Callet TEXT with all EXTRUDE CURVE INSIDE.
DRAG OUT the NULL Called TEXT with all extruded inside out and make keyframe for all EXTRUDED BLOCK.
now you can add nota tag to this NULL.
You must learn how is working Separate Letters and Hierarchical on extrude and is not NOTA job but Cinema 4D job.
Now i’m busy but in few hours i’ll make for you a quicktime with all steps.. maybe that i’ll use audio 🙂
I hope this help
Renato T. -
Renatot
April 7, 2005 at 4:29 pm
