Activity › Forums › VEGAS Pro › Not working – Region text to be the file name in a batch render
  • Craig Scime
    January 22, 2008 at 7:35 pm
    I was just about to jump for joy and thank the lord that my 4 day search was over….that ed saved the day…I get this error
    C:\Program Files\Sony\Vegas 7.0\Script Menu\BatchRender-Regions.cs(347) : ‘Sony.Vegas.RenderTemplate’ does not contain a definition for ‘FileExtensions’
    To be sure I even tested it on another computer which i don’t use as much but also has vegas 7e on it, and works great, but this DAMN scripts are killing me. please dont give up on me now…kiddding, but what do you think it is
  • Edward Troxel
    January 22, 2008 at 7:54 pm
    [craig scime] “FilesSonyVegas 7.0Script”
    Here’s the difference!!!!
    I updated the Vegas Pro 8 one! There are a few differences between the two versions. So going back to Vegas 7, we get this change:
    https://www.jetdv.com/scripts/BatchRender-Regions7.cs
    See if that one works for you.
    Edward Troxel
    JETDV Scripts
  • Craig Scime
    January 23, 2008 at 2:47 pm
    Wow this really worked…Thank you, Thank you. I wish I would have gotten this script from you from the getgo, it would have saved us both so much time. I really thank you for haning in there. People like you that make this forum a success. I have been to your site, but I never found this script there; is there other sites that have scripts like this, or others that you recommend? Again thank you Ed 🙂
  • Edward Troxel
    January 23, 2008 at 5:01 pm
    I did not actually make this script until you had problems finishing it. Then I made the changes to the Vegas 8 version and uploaded it. When you mentioned you were on Vegas 7, I then had to locate the Vegas 7 version, modify THAT one, and then upload it. So they were NOT on my site until just before I created the posts referring to them. I probably should go ahead and list them as available on my site.
    Edward Troxel
    JETDV Scripts
  • Carlos Pratt
    February 16, 2009 at 9:16 am
    can you help me, i need script for vegas 8, this one does not work!
  • Tobias Hame
    November 24, 2009 at 4:49 pm
    Hello Edward Troxel,
    I just discovered your script to render regions as the region labels and would find it very useful, unfortunately it only lets me render in .mp4 instead of quicktime.
    If i may ask, are there some lines i could add to get the multiple-codec options that exist in the standard Batch Render.cs
    I am using Vegas Pro 9.0 (64bit)
    Thanks a lot,
    Tobias Hame
    In general the difference between theory and practice, in practice,
    is larger than the difference between them in theory…
  • Luis Pena
    February 12, 2010 at 8:03 pm
    i was about to jump for joy when i realized that i have SONY Vegas 9 and i’m getting an error0x80131600 after copying your file batch.cs
  • Daniel Payne
    March 10, 2011 at 8:42 pm
    Hi I’m using Sony Vegas 10 and this .cs file isn’t working – or rather, it works but I only have the option to render to Sony AVC. Is it a simple matter to adapt the script to Vegas 10?
Page 2 of 2
