Activity Forums Apple Final Cut Pro Legacy No direct export of MPEG2 from FCP5?? A feature, not a defect.
  • No direct export of MPEG2 from FCP5?? A feature, not a defect.
    Posted by Michael Moser on May 20, 2005 at 7:04 pm
    This is one of those things that’s a ‘feature, not a defect’ according to what I’ve been able to find out so far.
    When I move a sequence from FCP 4.5 to DVD Studio Pro, I have been exporting a file ‘using QuickTime conversion;’ selecting
    MPEG2 from the list; and choosing bit rate and quality from the ‘options’ pop-up.
    I’ve been happy with the results. The DVD’s seem to work well in the venue (sports videowall) and it looks good.
    Apple has eliminated this option from FCP5/QuickTime 7 according to the person I spoke to there. One needs to create the
    MPEG2 asset by opening DVDSP or Compressor and doing it through those programs.
    Is there something I’m missing here? Could the results have been better had I used DVDSP or Compressor to build the assets?
    Aren’t they all using the same codecs?
    Why would they eliminate MPEG2 exports directly from
    Final Cut Pro.
    I assume a lot of other people use this method, but maybe not. Am I in the minority here?
    Michael Moser
    Sean Lander replied 21 years, 3 months ago 7 Members · 13 Replies
  • 13 Replies
  • Steve Eisen
    May 20, 2005 at 7:18 pm
    Quality is the same codec. Compressor, FCP 5 and A. Pack have been improved.
    G5 Dual 2.5 160GB System 400GB Media Drive ATI 9800 256MB 6 GB RAM
    Dual Gig Quicksilver 1GB RAM 80 GB System drive (3) 250 GB internal media storage
    15″ Al Powerbook 1.25 1GB RAM
    OS 10.3.8 FCP 4.5, DVDSP 2, QT 6.5, Boris Red 3GL 1.65 TB External Stor
  • Jeff Carpenter
    May 20, 2005 at 7:29 pm
    I guess they’re trying to steer people into using Compressor. It certainly has a lot more options than QT does, so I guess Apple wants to make sure people are aware of that.
    I do think it’s odd to do it this way, but I can see why they’d do it.
  • Michael Moser
    May 20, 2005 at 8:41 pm
    That’s what I was thinking.
    However, I find in many cases simpler is better.
    -M
  • Michael Moser
    -M
  • Matt Callac
    May 20, 2005 at 9:35 pm
    I’ve found that exporting Quicktime goes much faster than the compressor, so i ususally do it that way. That sucks that they took out the feature.
    matt
  • Alexander Kallas
    May 20, 2005 at 10:18 pm
    It’s all about quality. Compressor has more control. Why sacrifice this for a percieved speed advantage?
    Alexander
  • Sean Lander
    May 20, 2005 at 11:05 pm
    Can you tell me if it’s possible to do muxed Mpeg 2 files with compressor?
    This is very important to me.
    Apple Certified Final Cut Pro Trainer
    [b]R E D N A I L – M E D I A[/b]
    https://www.rednail.com.au
    email: sean@rednail.com.au
  • Alexander Kallas
    May 21, 2005 at 1:47 am
    Hi Sean,
    As an Apple Certified Final Cut Pro Trainer, you should really know the answer already.
    Read this thread https://archive.avsforum.com/avs-vb/history/topic/373960-1.html
    Cheers
    Alexander
  • Michael Moser
    May 21, 2005 at 3:47 am
    I still think it would be easier to just do the QT conversion. I am forced to use Compressor
    which isn’t altogether a bad thing. It’s just that it seems I have to jump through a few more
    unnecessary hoops.
    -M
  • Sean Lander
    May 21, 2005 at 8:21 am
    Really? Being a certified FCP trainer entitles me to something?!
    Could you please tell Apple Australia that.
