Activity › Forums › Maxon Cinema 4D › No alpha channel ?
  • Adam Trachtenberg
    January 7, 2010 at 3:43 pm
    Since an alpha channel is grayscale there’s no need for 16 or 32 bit.
  • Brian Bennett
    January 29, 2010 at 5:45 am
    I was having this same problem. I couldn’t figure out how to render out an object with and Alpha Channel background and then I found out from my instructor at school what I was doing wrong. Tim Shetz is absolutely correct. I was rendering using “Make Preview” instead of “Render to Picture Viewer”. As soon as I rendered using “Render to Picture Viewer”, it worked perfectly. Hope this helps:
    Settings:
    QUICKTIME
    1920 x 1080
    Animation codec
    Lossless
    millions+
    Alpha Channel is checked
    Straight Alpha is checked
    Render using “Render to Picture Viewer” NOT “Make Preview”
Page 2 of 2
