Activity › Forums › Adobe After Effects › Newbie Question: Why does my text keep shaking?
Barend Onneweer replied 15 years, 1 month ago 5 Members · 11 Replies
Barend Onneweer
July 22, 2011 at 8:55 pmWhat you are seeing is the on-the-fly low quality ‘pixel-aspect ratio correction’ in AE. You’re using non-square pixels and AE is stretching the picture in realtime to it’s intended aspect ratio. But AE’s realtime PAR-correction defaults to a low quality scaling that results in the nasty anti-aliasing jitter that you’re seeing.
Turn off PAR correction to double-check this is the case (button in the bottom of your Comp Viewer).
Raamw3rk – digital storytelling and visual effects
