Activity › Forums › Panasonic Cameras › New Snow Leopard P2 Drivers
Joel Jackson
March 17, 2010 at 6:39 pm -
Jeremy Garchow
March 17, 2010 at 6:53 pmOK. Then as a test, shut everything down. Turn off whatever is connected to your tempo card and unplug your MXO2, then restart.
There most definitely can be a driver conflict.
Jeremy
Steve Wong
June 7, 2010 at 3:27 pmHello There
I was reading your post from March 2010 re:ajpcd20 mounting with 10.6 and thought you may have some advice as I am having issues with my ajpcd20 that is inline with a power pc g5 2.3 running os 10.5.8.
The card reader worked fine before 32gig cards and since then I’ve installed new drivers several times and
have not been able to get the reader to read through FW only usb. I’ve reinstalled everything from OS to as I said drivers with the exception of the original disc that came with the ajpcd20 when I bought it 5 years ago. I’ve upgraded the firmware to the unit through a PC and still no success.
Can you help?
Steve -
Jeremy Garchow
June 7, 2010 at 3:52 pm[Steve Wong] “I’ve upgraded the firmware to the unit through a PC and still no success. “
Is it only 32GB cards that don’t work?
Are you lopping the unit through another firewire device?
You have installed the Leopard compatible drivers and not the Snow Leopard drivers, correct?
https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/macp2driver_e.htm
Jeremy
Steve Wong
June 7, 2010 at 4:04 pmNo snow L Tiger is my os 10.5.8
no looping diriect FW 800 to back of computer
no cards will read at this time either 8gig or 32 with FW 800
both 8 n 32 only mount with usb -
Arthur Aldrich
June 7, 2010 at 4:10 pmI have blown out the FW port on the PCD20 a couple of times. It is very sensitive…
Art Aldrich
OTEK TV
Leader, NJFCPUG
http://www.njfcpug.org
http://www.otek.tv -
Jeremy Garchow
June 7, 2010 at 4:13 pm[Steve Wong] “No snow L Tiger is my os 10.5.8 “
I understand, but you haven’t mistakenly install the SL drivers have you?
I’m with Arthur, it is possible that the fw port is bad on the PCD20.
Jeremy
Steve Wong
June 7, 2010 at 4:29 pmOkay
Is there any other test I can perform on the FW port
before I send the unit in for service?
