Activity › Forums › VEGAS Pro › Nero Express making a video DVD: Error the following files may not reside in the VIDEO_TS directory
John Rofrano replied 13 years, 5 months ago 3 Members · 14 Replies
Thayalan Paramasawam
March 26, 2013 at 8:55 amThank you very much Mr.John Rofrano for the explanation but i still have few questions.Now i am start to use DVD ARCHITECT.For Dv avi file i use mainconcept mpeg 2 for render the project file.So on custom setting which output type should i select for DVD ARCHITECT,previously i select dvd for render,then i use tmpeg dvd authoring for dvd output.
Now i remove the tmpeg dvd authoring programe and start to use DVD ARCHITECT.
On below i post the custom setting.Pls help me on this matter.
Thank You
Thayalan Paramasawam -
John Rofrano
March 26, 2013 at 10:38 amYou have the basic flow correct. Here is how it goes (Assuming you are in a PAL country):
- Render your video using MainConcept MPEG-2 with the DVD Architect PAL Widescreen video stream template.
- Then render your audio using the Dolby Digital AC-3 Pro type using either the Stereo DVD or 5.1 Surround DVD template depending on your projects audio properties. Give the audio file the same name as the video file but with the .ac3 extension.
- Then drop the video file into a PAL Widescreen DVD Architect project and create any menus you want and burn. You can also make a DVD with no menus.
If you don’t want to worry about all the rendering stuff, just get VASST DVDPrep and let it do it all for you.
It’s a free download from us at VASST and will render both the video and audio and take care of selecting the correct templates for you so that you don’t have to know anything.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
March 26, 2013 at 11:43 amHi Sir (Mr.John Rofrano)
Thank You….Thank You….Thank You…..
I am really happy……..at last i get some no knowledge from u…..Thanks a lot for improving my video editing and more……
Thank You
John Rofrano
March 27, 2013 at 11:45 am
