Need to Import Files Formated for Final Cut to Sony Vegas Pro 13
Norman Black replied 10 years, 11 months ago 4 Members · 11 Replies
Norman Black
September 18, 2015 at 2:35 am[Aaron Star] “Peoples hatred of CLI is amazing.”
Well, FFMPEG is a PITA to use so I understand that, but it can do just about anything and most of it’s encoders are actually better than most commercial options.
One thing ffmpeg has a problem with is RGB to YUV conversions which I found out about when I started using ffmpeg to frameserve from Vegas. It was easier to use Avisynth commands than try and figure out how to make ffmpeg do it right.
I use ffmpeg to frameserve from Vegas for encoding.
Here is an example to x264
@echo offtitle encode crf23
cd d:\renders
d:REM output the AviSynth commands
echo AviSource("server.avi") > server.avs
echo ConvertToYUY2(matrix="rec709") >> server.avs
REM echo ConvertToYUY2(matrix="PC.709") >> server.avsc:\systools\ffmpeg32\bin\ffmpeg.exe -i server.avs -c:v libx264 -preset medium -profile:v high -me_method umh -crf 23 -colorspace bt709 -color_primaries bt709 -color_trc bt709 -
pix_fmt yuv420p -bufsize 40M -maxrate 40M -c:a libmp3lame -qscale:a 2 -chunk_size 64K output.mp4pause
del server.avs
I have one that encodes ProRes from Vegas as well.
I have other standalone scripts which combine the mono channels in XDCAM and XAVC MXF files so Handbrake can encode them. Handbrake cannot handle the multiple mono channels of MXF.
Cliptoolz Convert is free and while no longer developed is probably the best utility to easily convert some camera format to edit formats like DNxHD, XDCAM and ProRes. Sadly no XAVC Intra, but that came after development stopped.
