Activity › Forums › Apple Final Cut Pro Legacy › Need some advice with frame rate conversion
Shane Ross replied 12 years, 7 months ago 6 Members · 13 Replies
Evan Warner
July 19, 2012 at 2:23 pmIsaac,
Did you ever figure out a solution to your ghosting? I’m trying to do a conversion from 23.976 to 25 fps for a PAL release and am getting the exact same ghosting on my clips using compressor. None of my clips are interlaced to begin with and considering I’m only making up for ~1 extra frame I was really hoping compressor would do the trick. I have tried both best and better motion compensation and get the same results.
Here’s a screen grab. Check out the arm. And no this isn’t motion blur because it’s not present in the original clip. Any ideas?
Cheers
Evan Warnerhttps://www.mysterycreative.ca
Maik Wieczorek
February 11, 2014 at 10:58 amAre there any solutions for the problem that Evan described above? 1.5 years later, I am facing the same problem, using apple compressor and trying to convert 23,9 fps to 25 fps. I can either choose beetween “ghost” pictures after converting with the best “movement compensation” in the compressor settings… or a slightly stuttering picture without ghost pictures.
Greetings, Maik
Shane Ross
February 11, 2014 at 5:04 pmThat is the only way, if you don’t want to change the speed…ie CONFORM 24fps to 25fps, therefore speeding it up 4%. Even the Terranex converters either repeat a frame, or have slight ghosting. There is no smooth way to add one frame per second…unless you adjust the speed.
Shane
Little Frog Post
