Need h.e.l.p with an audio effect
John Hancock replied 12 years, 9 months ago 7 Members · 28 Replies
John Hancock
November 27, 2013 at 7:18 pmGuys, i still haven’t found out how to do what i want to do, i even have everything updated (Vegas 12 build 726) and i still don’t see the option you told me to use, heck, the layout looks different on mine then yours!
Edit: Found out there is a new version that came out on the 22th. I will update, but i am going to say now that i doubt it will have the option.
John Hancock
November 27, 2013 at 10:51 pmIs that it? No idea what i can do to use automation? Any 3rd party VST’s i can get?
Graham Bernard
November 28, 2013 at 7:43 am_______________________________________________________________
[John Hancock] “I go into the audio FX, add Elastique then i check for the option configure FX automation and i can’t find it, or atleast don’t know what it looks like.”
_______________________________________________________________I can see what you’ve done, you haven’t followed what was outlined above, in which case you wouldn’t be seeing the Automation option. Please read this again, carefully.
Cheers
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Graham Bernard
November 29, 2013 at 6:00 amAm I correct in seeing you adding the Elastique to the EVENT? Where I added Elastique to the TRACK. Once I do that I could get all the Automation Controls needed – for the Track.
Grazie
John Hancock
November 29, 2013 at 4:12 pmOk, just got the 2 confused, should work now.
Can you use it just on an individual clip? -
Graham Bernard
November 29, 2013 at 7:23 pm_______________________________________________________________
[John Hancock] “Can you use it just on an individual clip?”
_______________________________________________________________When you say “Clip” you mean Event. Yes. Two ways:
1] Just apply the adjustments to the envelop FOR the duration of that EVENT.
OR
2] Have a separate Track JUST for that Audio EVENT.
Grazie
