Activity › Forums › Apple Final Cut Pro Legacy › Nattess Standards Conversion – NTSC DV?
Alec Gitelman replied 19 years, 5 months ago 2 Members · 12 Replies
Graeme Nattress
April 25, 2007 at 12:11 amOk, conversion in terms of field order looks fine. Both appear to be lower field PAL. However, the frame size is still 720×480 which is not PAL. FPS is correct at 25fps.
So, make sure you’ve in a full 720×576 PAL timeline, 25fps.
To increase the sharpness of the final render (maybe a little more jerky, but you can perhaps fine a balance) drop the motion blur parameter to around 15%.
Other than that they look fine.
Graeme
– http://www.nattress.com – Film Effects and Standards Conversion for FCP
Alec Gitelman
April 25, 2007 at 2:37 amframe size – that was a mistake transcoding to sorensen 3.
thank you very much.
i’ll keep experimenting.
