Activity › Forums › Storage & Archiving › NAS set-up for video production advice
Bob Zelin replied 6 years, 7 months ago 6 Members · 21 Replies
Bob Zelin
May 29, 2018 at 11:56 pmMichael Juhl’s system is now working properly with writes over 600 MB/sec and READs at 800 MB/sec.
It’s amazing how things work correctly, when they are setup properly.
Bob Zelin
Bob Zelin
Rescue 1, Inc.
bobzelin@icloud.com -
Mark Burkett
May 30, 2018 at 4:12 amGreat news!
I will go ahead and purchase the components. Thanks again and I will be in touch Bob if your expertise are required.
Mike Juhl
May 31, 2018 at 2:52 pmYes, thanks for your help Bob!!
It’s working great now and the 60% boost is speeds is excellent! -
Alex Pickup
June 19, 2018 at 3:36 pmHi Bob
You seem to be the man in the know! I was wondering what you thought about the new Thunderbolt 3 Qnaps? My instinct is that I won’t saturate that connection with 8 drives so they seem expensive to me maybe. However I wouldn’t need any adapters so would save there.
All I want to do is have a NAS running dropbox as we use that for everything (we’re based in many locations). In addition I would like to attach my PC and Mac Laptop to the NAS directly so they can share files and I can edit video straight off the box.
I am thinking that a 10gbe direct connection to both systems would be plenty of speed?
My PC has thunderbolt 3 and 10gbe connections already on board
My laptop has thunderbolt 3 only. So I guess I’d need the expensive converter box for that which might use up some of the price difference between the non-thunderbolt and thunderbolt qnaps.
The two I’m considering are: Qnap TVS-873e-8G or Qnap TVS-882BRT3-i5-16G and the price difference in the Uk is around £500.
I’d love any advice and also once I’ve got the basic system going would you be up for remote access setup?
Alex -
Bob Zelin
June 19, 2018 at 8:25 pmreplies below –
REPLY – well, you need 8 drives. Period. The drives cost more than the QNAP. You will be using a 10G connection, not a thunderbolt 3 connection, to connect to your Mac or PC workstations.
REPLY – the QNAP can do an automatic backup to Dropbox. It’s a feature that’s built in for free. Of course, you can’t edit over the internet. It’s not fast enough. But you can move files around. You are at the mercy of your internet connection speed.
REPLY – you will connect via the 10G ports. Your Mac Laptop needs a Sonnet Solo 10G for thunderbolt 3 or Sonnet Twin 10G (or Promise SanLink2) for Thunderbolt 2. Your PC can use the ASUS or QNAP 10G NIC card, which is about $100 US. Yes, you can edit right off the QNAP.
REPLY – you will get about 900 – 1000 MB/sec from the PC if you use the ASUS or QNAP 10G PCIe card (or the Sonnet Presto 10G, which is about $280 US). With the Solo 10G Thunderbolt 3 adaptor, you will get 900 – 1000 MB/sec and with the thunderbolt 2 adaptors, you will get about 800 MB/sec. If you get the cheaper Akitio, you will only get about 300 MB/sec.
REPLY – if its not the horrible Startech 10G that uses the Tehuti 10G chip, then you are ok. We can try it, and then add the ASUS 10G card for $99 if there are issues. The ASUS, and QNAP both use the Aquantia ACQ-107 10G chip which is the same chip that’s in the iMac Pro.My laptop has thunderbolt 3 only. So I guess I’d need the expensive converter box for that which might use up some of the price difference between the non-thunderbolt and thunderbolt qnaps.
REPLY – the Sonnet Solo 10G is $177 at B&H Photo in the US. I am sure that https://www.span.com in London sells it as well. If you consider this to be expensive, then we are both wasting our time right now.The two I’m considering are: Qnap TVS-873e-8G or Qnap TVS-882BRT3-i5-16G and the price difference in the Uk is around £500.
The TVS-873e is a bare bones 8 bay box, with no 10G card in it. You MUST order either a QNAP LAN-10G2T-X550 card for this ($359 US) for dual port connection, or if you are getting a 10G switch (like the QNAP QSW-1208-8C which is $589 US) then you order the QNAP QXG-10G1T card for $139 and put this into the QNAP TVS-873e. This is a single port card, that connects to a switch.
The TVS-882BRT3 is a backup unit. Why would you consider this model ?Ask any other questions that you may have. I do this all the time, all day long.
Bob Zelin
Bob Zelin
Rescue 1, Inc.
Alex Pickup
June 19, 2018 at 9:46 pmHi Bob
Thanks for the replies! I’ve answered again on each piece below trying to clarify bits:
replies below:
Alex Reply: Ah sorry what I meant was just ‘will my 8 drives actually saturate a 10gbe connection? Or would the extra bandwidth of 40gb/s thunderbolt 3 give me something extra? From what I gather you aren’t a fan of Thunderbolt 3 qnaps though having just found some other threads.
Alex Reply: Yep understood on that. Currently we tend to run a big dropbox volume on an external hard drive or external raid (around 6TB of synced data at any time) and I work ‘live’ on that volume via thunderbolt on my computer. Dropbox is constantly syncing everything as fast as it can as things change. Now I want to have that volume syncing on the NAS and be working directly on that volume via 10gpe or thunderbolt 3 using my mac or my PC. I assume that’s doable as a friend of mine does in on a synology nas but just wanted to clarify the aim.
Alex Reply: Sweet
Alex Reply: gotcha
REPLY – if its not the horrible Startech 10G that uses the Tehuti 10G chip, then you are ok. We can try it, and then add the ASUS 10G card for $99 if there are issues. The ASUS, and QNAP both use the Aquantia ACQ-107 10G chip which is the same chip that’s in the iMac Pro.Alex Reply: This is the motherboard I have so it looks like I have the Aquantia AQC-107 10G like you said. You know everything!
https://www.asus.com/uk/Motherboards/ROG-RAMPAGE-VI-EXTREME/specifications/My laptop has thunderbolt 3 only. So I guess I’d need the expensive converter box for that which might use up some of the price difference between the non-thunderbolt and thunderbolt qnaps.
REPLY – the Sonnet Solo 10G is $177 at B&H Photo in the US. I am sure that https://www.span.com in London sells it as well. If you consider this to be expensive, then we are both wasting our time right now.Alex Reply: No it’s fine, I was just factoring in that £200 in case it made one qnap vs another become closer in price.
Alex Reply: Ahh yes I get you, I missed that. Okay well before I decide on getting that one plus the 10gb card is there a different 8-bay qnap with 10gb already built in that you’d recommend? My UK options are here: https://www.span.com/category/Qnap-NAS-8-Bay~3005
Alex Reply: Ah that’s interesting. I’d had this model recommended to me specifically for using as attached video editing via 10gbe and thunderbolt 3. Nobody said it was a backup unit. It looks like a fully fledged unit on the website. Would it be much worse than the TVS-873e then? Here’s the specific listing I was considering:
https://www.span.com/product/Qnap-Desktop-NAS-10GbE+TB3-TVS-882BRT3-i5-16G-8-Bay-RAID-0-1-5-6-16GB-RAM-Core-i5-+-5-25-Bay-+-Thunderbolt-3-+-10GbE-by-T2E-~61974/spanstor=41629Ask any other questions that you may have. I do this all the time, all day long.
Alex Reply: Thanks man. I guess my big question still is why the thunderbolt 3 units should be avoided? Some of the posts about this have gone over my head tbh. This is my first NAS and I’m not up on all the ins and out. I am definitely getting the vibe that there’s no point in that platform but I’d love to be fully illuminated on the issues with those. Are they just a distraction in this market?
Thanks again and I’ll happily get what you recommend and then be in touch to have you help me set it up remotely.
Appreciate the help
AL -
Bob Zelin
June 19, 2018 at 11:10 pmAlex Reply: Ah sorry what I meant was just ‘will my 8 drives actually saturate a 10gbe connection? Or would the extra bandwidth of 40gb/s thunderbolt 3 give me something extra? From what I gather you aren’t a fan of Thunderbolt 3 qnaps though having just found some other threads.
REPLY – this is correct. While the TVS-1282T3 and TVS-882ST3 are fantastic units, they are fantastic when they are used with 10G connections. With the advent of the Sonnet Solo 10G for $177 street price, what’s the problem ?
It’s CHEAP !Alex Reply: This is the motherboard I have so it looks like I have the Aquantia AQC-107 10G like you said. You know everything!
https://www.asus.com/uk/Motherboards/ROG-RAMPAGE-VI-EXTREME/specifications/REPLY – OH I LOVE ASUS motherboards. This is the motherboard that Blackmagic recommends for Davinci Resolve when you are going to build your own Win PC. It’s great. Aquantia is great !
REPLY – people think that “oh, I have this FREE built in thunderbolt 3 port, I can have this connection FOR FREE !”.
You are limited to a 2 meter connection with thunderbolt 3. If you extend, you drop down to thunderbolt 2 speeds. With the Sonnet Solo 10G for $177, you can run 55 meters at FULL SPEED, and if the cable breaks, you spend 10 quid to replace it. And you will have a super reliable connection. There is this fascination with thunderbolt 3 connection, as if it’s some miracle. It’s not. What I can say, is that if you don’t care about a shared storage system, and just want a big drive array, you can purchase a wonderful thunderbolt 3 RAID array from G-Tech, Promise, or Areca, and just plug it in, and it will work, without any configuration from me. Now, THATS easy. The QNAP is not that easy. No network attached shared storage system is.Bob Zelin
Bob Zelin
Rescue 1, Inc.
Fajar Damanik
November 22, 2018 at 2:00 pmHi Bob,
Seems like everyone got a great advice in here from you. But I have question with your TVS-873e.
We need NAS storage that can handle multiple FCP user at the same time to edit in-place from the storage, the scratch disk it self will be on the NAS storage. Using 1G NIC seems enough if we run playback 3-4 streams HD ProRes, so no need 10GB to each user.
But what I concern is, can this storage able to handle multi user at the same time (let say 3-4 user)? is there any speed reduce while read access 1 same file by multi user at the same time?Thanks in advance,
Raymond. -
Bob Zelin
November 22, 2018 at 2:53 pmRaymond or Fajar –
ProRes 1080i 29.97 is about 20 MB/sec. So 3 – 4 streams unrendered is 60 – 80 MB/sec. Will this work over a 1G connection that can provide 100 MB/sec. Maybe – theoretically. But when you watch a performance graph when asking for this bandwidth, you don’t get a nice flat line of 100 MB/sec – you get spikes and peaks. So with 4 streams, you might get stuttering.
Either way, you MUST use the 10G port on the QNAP (or Synology or anything else) to go to a 10G switch, and your clients must have independent ports (not sharing the internet ) to go to this 10G switch. So your “savings” of not getting a 10G adaptor for the computer is –
$175 for a Thunderbolt 3 Mac computer
$100 for a Windows 10 computer
and (unfortunately) $500 for a Thunderbolt 2 Mac computer.To insure you have the ability to playback 4 streams of ProRes 29.97 1080i, I would get the 10G adaptors.
The total aggregate READ speed of the TVS-873e is about 1000 MB/sec, so if you have 4 guys all using a total of
400 MB/sec, then YES, all the editors can read the same media at the same time, without getting stuttering.
Make sure to get ALL EIGHT DRIVES (all 7200 RPM) in a single static volume. IF you do not purchase the optional 10G card for the QNAP ($89 bucks – it’s the QXG-10G1T) and a 10G switch, you are wasting your time and money.Bob Zelin
Bob Zelin
Rescue 1, Inc.
David Monteagudo
January 17, 2020 at 9:22 pmHi Bob,
I came across your post and wondering if you might be able to help me out. I recently purchased the QNAP TS-1685 to upgrade my employers system. We were previously using a GTech Shuttle XL w/ Thunderbolt 3. I’ve also got the Dual-port SFP28 25GBE Network Expansion Card. We’re editing a project in Davinci Resolve 16 with mostly 8k R3D files. Previously, I was able to get smooth playback from the GTech Shuttle XL with the debayer setting to Half Res Good. However, I’m getting choppier playback from the new QNAP NAS which wasn’t what I had anticipated. Wondering if you have any suggestions for tweaking the configuration of the NAS to improve the performance? Let me know if there’s any more info I can provide to paint a clearer picture.
Best,
Dave
