Activity › Forums › Apple Final Cut Pro Legacy › MXF files from the Canon C300 and Final Cut Pro 7
Shirley Chi replied 12 years, 9 months ago 14 Members · 24 Replies
Leo Chou
March 7, 2013 at 3:12 pmI am using FCP 7, and as far as I know it does not read Canon C300 files natively. I tried Canon XF utility, with very limited success, on few different machines. Main problem with that piece of software is that it expects to see compact flash cards straight from the camera and doesn’t seem to work very well with folders on an HDD. I was suggested to convert MXF clips to Apple ProRes 422 using UFU Soft MXF Converter for Mac, because FCP 7 needs to have all the footage on a timeline in the single codec, otherwise it needs to render everything and does not preview clips in realtime. The Canon Video Converter tool is able to load MXF files directly from the camera, or read from a folder stored on your computer’s HDD or an external hard drive, as well as separate .MXF clips out of the camera’s original folder structure. Plus, this solution is particular helpful when you need combine footage coming from different cameras with different video modes. Best of all, it is capable of keeping multiple audio tracks in your source material.
Simen Gorden
June 6, 2013 at 3:59 amI have saw an article that convert mxf file to apple prores, maybe you also can try this method, I think this will be work. https://jackstar.blog.com/how-to-convert-canon-eos-c500-mxf-video-to-apple-prores/
Eason Joy
June 19, 2013 at 9:49 amYou can convert and transcode Canon C300 MXF files to Apple ProRes 422 MOV for Final Cut Pro 6 /Final Cut Pro 7/Final Cut Pro X follow this guide: https://www.mxf-video-converter.com/make-canon-c300-mxf-compatibility-with-fcp-convert-mxf-to-final-cut-pro-67x-mov/
Shirley Chi
November 27, 2013 at 3:24 amOne advantage of the Canon XF codec is that it’s already supported by the major NLE software applications.
But XF plug-in/XF utilities cannot work well with 1080i, 1080P videos. I searched internet and trie to get a solution. An article-Transcoding from Canon C300 MXF to Apple Pro Res with two channels of audio, I once collected may be helpful. Of course, only if you don’t mind that using a conversion tool.
