Activity › Forums › Creative Community Conversations › Musings on FCPX’s most powerful feature.
Aindreas Gallagher replied 13 years, 6 months ago 20 Members · 100 Replies
David Lawrence
February 21, 2013 at 12:37 am[Herb Sevush] “[Franz Bieberkopf] “That is the way I work, and all my clips go into sequences without any previous selection or marking.”
+1″
Yep!
_______________________
David Lawrence
art~media~design~research
propaganda.com
publicmattersgroup.com
facebook.com/dlawrence
twitter.com/dhl -
Brett Sherman
February 21, 2013 at 12:38 amFor me it’s a group of features that as a whole make finding footage a lot faster than it ever was in FCP 7 or Avid for that matter. Skimming, favorites, size of thumbnails, thumbnails update about 5X faster than in 7 when skimming (this makes a huge difference in finding the right material without accidentally jumping over it), keywords, thumbnails in the timeline, etc.
I won’t say I’m 100% sold on the relational/magnetic timeline. There are things it does well and things it does not so well. It is neither a panacea nor a disaster. But I’m just learning it. My guess is that eventually I will be slightly faster with it than I am with 7. Right now I’m a bit slower.
But since I tend to spend a lot more time in the finding shots and soundbites part of the editing, I’m faster overall. And I enjoy editing more with X. That’s the trump card.
Charlie Austin
February 21, 2013 at 1:30 am[Kevin Monahan] “Check out Premiere Pro CS6’s “Hover Scrub” feature. Does what you want, as well:”
It’s a nice feature. But other than a vague behavioral similarity, it’s not anything like skimming.
~”It is a poor craftsman who blames his tools.”~
Charlie Austin
February 21, 2013 at 1:35 am[David Lawrence] “[Herb Sevush] “[Franz Bieberkopf] “That is the way I work, and all my clips go into sequences without any previous selection or marking.”
+1″
Yep!”
-1 Nope! lol
It would be nigh impossible for me to cut that way. My cut sequences generally end up between 5 seconds and 2.5 minutes long. My source clips are generally 1.5 to 2 hours long, with up to 5 stereo stems embedded. it would be an unimaginable nightmare to try to cut that way. I guess it depends on what sort of program you;re doing…
Franz Bieberkopf
February 21, 2013 at 1:40 am[Charlie Austin] “My cut sequences generally end up between 5 seconds and 2.5 minutes long. My source clips are generally 1.5 to 2 hours long, with up to 5 stereo stems embedded.”
Charlie,
Your typical ratios and sources sound quite similar to mine.
To each his own method.
Franz.
Charlie Austin
February 21, 2013 at 1:43 am[Sandeep Sajeev] “How do you cut together complex scenes with foley, location audio, music etc without going into the timeline?”
You don’t. 🙂
Unless you create a CC in the event and open it in a timeline. But then you’re in the timeline. You could probably assemble a keyword collection of, I dunno, interview clips or B-roll using ranges/favorites and then drag them all into a sequence, but for what you describe, there’s no reason to try. Use a timeline. 🙂
Charlie Austin
February 21, 2013 at 1:44 am[Franz Bieberkopf] “Charlie,
Franz.”
Yep… I’d really like to see how you do it. My head would explode. 🙂
Franz Bieberkopf
February 21, 2013 at 1:49 am[Charlie Austin] ” My head would explode.”
That’s probably the main reason I resist editing-as-spectator-sport.
Franz.
David Lawrence
February 21, 2013 at 1:51 am[Charlie Austin] “Yep… I’d really like to see how you do it. My head would explode. :-)”
Some of us have been using the timeline in Legacy for skimming for years. Just saying… 😉
David Lawrence
propaganda.com
twitter.com/dhl -
Charlie Austin
February 21, 2013 at 1:59 am[David Lawrence] “[Charlie Austin] “Yep… I’d really like to see how you do it. My head would explode. :-)”
Some of us have been using the timeline in Legacy for skimming for years. Just saying… ;)”
Explain how that works. say I’ve got a spot I’m cutting in a sequence. So I open another timeline?, drag my 2 hour source into it, drag the playhead to an in point and… then what? i guess I don’t get it, but how’s that different from using the viewer?
