Activity › Forums › Apple Final Cut Pro › Multicam Synchronization is so slow
Bill Davis replied 11 years, 7 months ago 8 Members · 16 Replies
James Culbertson
February 10, 2015 at 11:37 pm3 hours seems like something is wrong. Shouldn’t take more than 5-10 minutes to sync at the longest for a 2 hour 2-3 camera (single clip or broken up clips). Most of the time much less. At least that is my experience. Have you set the camera angle field correctly?
Daniel Elder
February 11, 2015 at 12:04 amHere’s how I set up the Camera Angles, based on a video I watched on it.
I didn’t think it would take that long. Also, when I did a smaller selection (1 Take), which had 3 video and 4 audio channels, they weren’t in sync, is there something I need to do to prep the files to be in sync?
Daniel Elder
producer
http://www.elderpictures.com -
Bill Davis
February 11, 2015 at 6:18 amNot quite sure why you’re using such complex names for your angles.
All they do in the X database is allow it to understand what to put on the same track in the Angle Editor – and what to split onto separate tracks.
All I ever use is A, B, C, D, etc.
The rest of the ascii characters are irrelevant. So why force the program mess with them?
FWIW.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
Daniel Elder
February 11, 2015 at 8:11 amI didn’t know better.
So for Camera’s I’ll use A, B, C, D and for Audio should I use X, Y, Z to sort the audio?
I’ll simplify it now.
Any other suggestions?
Daniel Elder
producer
Bill Davis
February 14, 2015 at 12:39 amDefinitely try what Jeremy suggests.
One thing about the way X does Multicam is that you can use it in an ADDITIVE fashion rather than needing to sync everything all at once.
In other words, If you have 20 cameras – but only 12 of them have good sync audio. You can sync just the 12 at first. THEN go back and add the additional angles that might be more problematic. Not only that, but you can elect to sync the first batch via audio waveforms, (or timecode or whatever) but then add additional angles based on OTHER sync criteria. So if cameras 13-17 all have a shot of a particular action – you can put manual markers on that sync point and then ADD those angles to your original 12. Then take a look at the last 3 angles and perhaps find a muffled audio hit, or a physical movement that is reflected in ANY of the already synced tracks, and use that as a sync strategy to add the next three.
X is almost amazingly flexible in this way, working well beyond the simple idea of “if EVERYTHING doesn’t work, then that means nothing is working.”
Have fun.
