Activity › Forums › Compression Techniques › mpeg streamclip problem!
Daniel Low
April 1, 2010 at 9:21 pm[Brian Alexander] “There all loaded with Qmaster (no license needed) which installs the ProRes encoder! “
Qmaster is part of, and only part of FCP. Therefore a licence is needed. Qmaster needs a licence. Qmaster does not install the Prores CODEC alone. ProRes is part of Final Cut Studio! Of which Compressor (and as such Qmaster) is a subset!
The ELUA is very visible as part of a standard FCP install.
Sent from my iPad Nano. -
Daniel Low
April 1, 2010 at 9:28 pm*EULA*
Brian Alexander
April 2, 2010 at 1:23 amFor clarification, it’s the Qmaster Node Installer that I was referring to, not Qmaster.
EULA: “Apple Qmaster Node Installer. The Apple Qmaster Software may be installed and used concurrently on as many Apple-labeled computers owned, leased, or otherwise controlled by you as reasonably necessary. These computers must be networked and running Mac OS X.”
https://www.apple.com/legal/sla/
Thanks Daniel.
