Activity › Forums › Apple Final Cut Pro Legacy › MPEG Streamclip Audio Out of Sync
Gregory Quinn replied 15 years, 8 months ago 11 Members · 16 Replies
Gabriel Figueroa
April 30, 2009 at 5:55 amI just had this problem myself in MPEG Streamclip but I got around it by exporting it to DV as oppose to a Quicktime movie.
Gabriel Figueroa
April 30, 2009 at 5:56 amI just had this problem myself in MPEG Streamclip but I got around it by exporting it to DV as oppose to a Quicktime movie.
Rick Dervisevic
February 6, 2010 at 5:24 pmI just finished converting 40 hrs of PAL footage from VOBs to MPEG4s using MPEG Streamclip. Of the 25 discs, 10 fell out of sync. Unusual issue though, the sync problem happens all at once as the video appears to fast forward for a couple of seconds in what appears to be a random point in time in each movie and then behold, out of sync for the rest of the movie. Any one encountered this one before????
thx
Rick -
Gregory Quinn
January 8, 2011 at 6:36 pmYep, just had the same problem. Fixed reported timecode breaks in the vob when opening in MPEG streamclip, and the converted video has speedup sections that hose the audio sync. Anyone found a solution?
Rick Dervisevic
January 8, 2011 at 11:03 pmits been awhile but if I recall, I didnt get an answer that solved the problem so I ended up editing out the speeded video and matching the audio manually with the remainder of the movie. Grueling and mickey mouse but it was the only option left.
Gregory Quinn
January 8, 2011 at 11:24 pmThanks Rick; seems like a bug in MPEG streamclip. I ended up buying DVDxDV which did the trick.
