Activity › Forums › Adobe After Effects › Moving Lights Made Easy?
  • Darby Edelen
    January 16, 2014 at 5:51 am
    I’m not sure what you mean by “in a different place.” There are different reference points involved in defining a “place” when you work in 3D.
    The 3D position of any object should not change so long as its position or any of its parent objects positions are not being animated.
    That said, when you look through a new camera the screen (2D) position of every object is going to change if the camera has different transforms from the previous one.
    Can you post a project file or images that illustrate the behavior you’re seeing along with a short description of how you’d like it to behave?
    Darby Edelen
Page 2 of 2
