Activity › Forums › Apple Final Cut Pro › Moving Events – How do you prevent duplicate clips and render issues?
Michael Angelo replied 9 years, 11 months ago 6 Members · 12 Replies
Tangier Clarke
May 19, 2016 at 5:03 pmProxy Copy Test
FCP X 10.2.3
Mac OS 10.11.5Work Computer/ External Thunderbolt RAID
Create Library “Proxy Copy Test A”
Event auto generated with current date.
Import preference set to “copy to library location”
Create optimized and create proxy options unchecked.
Import file (via drag and drop)
Available media representations after import: Original only.
Transcode imported clip to proxy file
Available media representations after transcode: Original and ProxyProceeding on same computer, installation of FCP X and user account
Work Computer/External Mini Thunderbolt Drive (to take home)
Create Library “Proxy Copy Test B”
Event auto generated with current date (same as above)
Import preference unchanged from above.
Create optimized and create proxy options unchanged from above.
Drag event from Proxy Copy Test A library to Proxy Copy Test B library.
Prompt to copy items to the library Proxy Copy Test B library. Original media will be copied. Proxy media checkbox checked to copy over.
New event created by copy process in Proxy Copy Test B library (since FCP X doesn’t allow same name events)
Delete original event in Proxy Copy Test B and rename the newly created one to match the event in Proxy Copy Test A. This should be OK because FCP X will not delete media from one event if it’s in another and still part of the same library. This allows me to keep things in sync.
Available media representations of clip in copied event: Original and Proxy
Reveal in Finder on clip in copied event shows proxy file (not alias) actually in the transcoded media folder on the mobile drive.Successful test so far. No duplicates. Proxies copied. This is not my normal experience.
Close all libraries
Quit FCP X
Plug in mobile drive on laptop and load librarySame Mac OS, same version of FCP X
Laptop/ Proxy Copy Test B library
Import preference same as above.
Create optimized and create proxy options samosa above.
Create a project called Proxy Test
Put clip on project storyline, make a few edits.
Import new clip.
Transcode clip to proxy file (media was shown as missing proxy since storyline playback setting was set to proxy)
Edit into storyline.
Assign keyword for both clips in browser called test clips.
Close library and quit FCP XPlug mobile drive back into work computer
Open Proxy Copy Test B library and Proxy Copy Test A library
Everything checks out for edits made, available media, and keywords
Now to update Proxy Copy Test A’s event with B’s event
Drag event from Proxy Copy Test B library to Proxy Copy Test A library.
Prompt to copy items to the library Proxy Copy Test A library. Original media will be copied. Proxy media checkbox checked to copy over.
New event created by copy process in Proxy Copy Test A library (since FCP X doesn’t allow same name events)
Delete original event in Proxy Copy Test A and rename the newly created one to match the event in Proxy Copy Test A. This should be OK because FCP X will not delete media from one event if it’s in another and still part of the same library. This allows me to keep things in sync.
Available media representations of clip in copied event to Proxy Copy Test A: Original and Proxy
Reveal in Finder on clip in copied event shows proxy file (not alias) actually in the transcoded media folder on the work external thunderbolt RAIDSuccessful test so far. No duplicates. Proxies copied. This is not my normal experience.
Repeat as needed.
This is my usual process and this time around it seems to be working. The difference between this test and my usual projects that run into proxies not copying over as well as lots of duplicate clips is I am using synchronized and multicam files.
Still not sure why I have that issue.
Tangier
Michael Angelo
October 11, 2016 at 4:02 amWatch the first 10 minutes of this video, specific workflow to duplicate multicam and create a transfer event to avoid duplicates created by dragging and dropping projects between libraries:
https://www.youtube.com/watch?v=NAv89cGexIM#action=share
Hope it helps in some way
MA
Harvest the compromises…
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
