Activity › Forums › Adobe After Effects › Motion Paths, Trapcode Particular, & 3D space, OH MY!
Joe Randazzo replied 17 years, 3 months ago 7 Members · 13 Replies
Francisco Cueto
February 24, 2009 at 12:02 amalmost there.
The second approach helped a lot, but i forgot to mention that i have to stick some elements inside this “tree”and the second method basically makes it really hard to render the particles that would go “behind”my element in a different layer since i can no longer use any of the Z tools inside particular.
any more ideas?
-F
Kevin Camp
February 24, 2009 at 4:41 pm[Francisco Cueto] “particles that would go “behind”my element in a different layer since i can no longer use any of the Z tools inside particular.”
when i first read your post, i thought of course it didn’t, i forgot to map the emitter’s z-pos to the null… but it turns out that you can’t derive z-pos with layer space transforms for a 2d layer (the particular layer) and if you make the particular layer 3d, you get the z-pos, but then it breaks the realism of the effect….
so, you’ll need another 3d null that you’ll use to get the 3d values, then pull those into particular…
first create a new null, make it 3d and zero the position values. enable expressions for its position and use the expression from before:
target = thisComp.layer(“Null 2”);
fromComp(target.toComp(target.anchorPoint));now you can use the expression pickwhip to link the emitter xy to the position of the new null. so it might look like this:
temp = thisComp.layer(“Null 3”).transform.position;
[temp[0], temp[1]]do the same for the emitter’s z, but change the end value from [0] to [2] to specify the z value. so it might look like this
thisComp.layer(“Null 3”).transform.position[2]
now you should be able to use the obscuration layer within particular (and other z space properties)…
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Joe Randazzo
June 5, 2009 at 8:50 pmAnother variant of the emitter question…
I have a path from illustrator that I’ve brought into AE as a masked layer. With Particular, how could I get that to reveal the text? I’ve been trying a bunch of different ways but cannot seem to get it correct.
Any advice?
