Activity Forums DaVinci Resolve Monitor Comparison
  • Lauri Laidna
    February 4, 2012 at 11:37 am
    If you need something bigger then consider Samsung 2011 line of TVs. Anything higher than D6000 has 10-point white balance option! I’ve calibrated few of them and you can get them extremely accurate! The beauty is that you can calibrate them internally with a remote control in the menu. So you get accurate image from whatever video source – DVD, Camera, editing application which does not have LUT correction etc.
    37″ doesn’t have Samsung panel, but smaller and bigger versions (UE32D6000 or higher, UE40D6000 or higher) do have.
    I think this ise the best good-enough solution out there. Of course this is only REC709 colorspace, which is also quite accurate! I couldn’t imagine working with clients with only 22-24″ screen, so perfect thing for second screen for the clients. The only issue is some light bleeding from sides if you work in very dark room.
    I think such solution beats low-end grading monitors, if you can’t afford LUT-based calibration or the monitor doesn’t have good integrated calibration.
Page 3 of 3
