Activity › Forums › Avid Media Composer › Mixed frame rates project
  • Michael Phillips
    May 9, 2016 at 1:25 am
    This was a workflow for older versions of Media Composer that may work for you:
    https://24p.com/wordpress/wp-content/uploads/2013/07/transcode-and-relink-across-projects-with-different-frame-rates.pdf
    Michael
  • Nick Gibbon
    May 9, 2016 at 8:38 am
    Hey Shane,
    thanks for your response. I’m running 8.4.1
    I’m going to create separate projects for each frame rate, AMA link then transcode to 36 for offline. Then I’ll create a master 25 project and open the bins from the other projects in that project (I noticed Michael said to “copy” those bins into the master project – is that the same as just opening those bins in the master project?)
    My question specifically was once I’ve finished offline at 25 how will Avid handle the original camera files in the conform for up-res, in terms of the clips with altered frame rates? Will it just apply the fps conversions to the higher res material in the background in the way that effects and transitions would carry over (It’s my first time in Avid going from offline -online at end of edit)?
    Cheers,
    Nick
Page 2 of 2
