Activity › Forums › DaVinci Resolve › Methods for getting screening notes into resolve?
Eric Johnson replied 12 years, 10 months ago 6 Members · 14 Replies
Nat Jencks
November 21, 2013 at 6:14 pmThats a good idea. I’m still holding out for TC entry to be a standard feature.
Given that Resolve is being marketed as an online editing platform these days, not being able to navigate to a specific timecode is really not workable. Looking forward to having this feature added.
best-
-Nat -
Michael Stirling
November 21, 2013 at 6:20 pmI’m doing a feature film review today and this has really made my day – might even make it home for dinner now.
It’s not even as complex as you thought as you don’t have to go to the deck control section.
Just enter in the in-point on the render page and then press shift i to jump to the TC.Being on the wave I don’t have shot no. entry but would say that shot numbers do change (ie. if ‘drop in this extra title slate’ was your first review note it would blow that whole workflow)
Nat Jencks
November 21, 2013 at 6:25 pmHi Marcus, I did a quick search on the forum for assigning macros and didn’t find anything, can you point me in the right direction in terms of your comment “Using well documented techniques on this forum of assigning complex macros to unsupported features in Davinci, you can match and even surpass the BM panel in terms of feature set. A lot of standard functions in the BM panel require two clicks or multiple buttons. Using your own setup you can get most of your needs down to one button.”
-Nat -
Eric Johnson
November 21, 2013 at 7:26 pm[michael stirling] “Being on the wave I don’t have shot no. entry but would say that shot numbers do change (ie. if ‘drop in this extra title slate’ was your first review note it would blow that whole workflow)”
I knew there was a reason I hadn’t done this yet… last time this came up I thought it would be a great idea, but then I had to do just that and everything became useless…
eric b johnson
online editor | colorist | workflow
https://vimeo.com/39073239Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
