Activity Forums Live Events & Streaming Method for Doing Multi-Screen Video
  • Walter Soyka
    November 26, 2012 at 9:54 pm
    [Clifford Steinberg] “Have you looked at BrightSign? They have cost efficient players that can be synced and respond to external triggers.”
    Maybe I misunderstood the interactivity requirement — if you are simply cueing existing motion media, the BrightSigns could be a good choice. I do have a couple of these and I’ve been really happy with their reliability (though I haven’t pushed them being looping and very simple single-screen cues).
    Can they return from a single media cue on one unit at its end into the correct point in a synced multi-unit cue?
    Walter Soyka
  • Pat Ford
    November 26, 2012 at 10:00 pm
    Thank you gentlemen,
    I took a quick look at BrightSign…and I have heard of them before. I am a lazy cuss…can someone tell me the difference between the BrightSign and the Adtec SignEdje? I have several of the Adtecs…they are worth considerably more than the Brightsigns…or at least they cost considerably more originally. (!)
  • Thomas Leong
    November 27, 2012 at 1:29 pm
    No experience with the Adtec SignEdje, but I have 2 Brightsign HD210. Tested the following so far with:
    – One media file (mpeg) looping all day. Perfect seamless loop, better than vlc on a pc which has a visible pause whereas the Brightsign did not. Same file (a Digtial Juice Jumpback).
    – Two media files – a panoramic split for bezel, etc., and controlled by an old router (to auto assign the IP addresses to each Brightsign over CAT-5). Perfect looped sync, all day. Brightsign claims 1-2 frames mis-sync may occur, but I did not see any with the media I fed it – a Maria Carey video with Snoop Dog – with lots of flash cuts, easy to see the sync between both monitors throughout.
    However, the Brightsigns (both operated as a standalone single unit, and as dual units controlled by a router) took some time to start playing the media on power up. As a single unit, about 1 minute. As dual units with router, about 2 minutes+, probably to acquire the IP addresses. But it is idiot proof operation – power up and play, even if powered down in the middle of playback, i.e. suddenly.
  • Thomas Leong
    November 27, 2012 at 1:38 pm
    If you want to add interactivity capabilites to the Brightsign, enquire/check this site out –
    https://bcdusa.com/content/view/120/183/
  • Clifford Steinberg
    November 27, 2012 at 4:30 pm
    I do not have any experience with the Adtec SignEdjes either.
    My experience with BrightSign includes:
    -3 units(HD1010’s) looping the same video with synchronization.
    -3 units with 3 plasmas to create a video wall, synced with ethernet and switcher – synchronization worked extremely well(as it is quite noticeable if a video wall is out of sync).
    -1 unit, controlled by Crestron touchpanel to allow user to play a specific video file.
    -BrightSign unit controlling projector over RS-232.
    Depending on how you want users to interact with your content on the televisions, BrightSign may be a viable option.
    [Walter Soyka]Can they return from a single media cue on one unit at its end into the correct point in a synced multi-unit cue?
    I have not created such a show, and it sounds quite difficult to do using BrightAuthor(BrightSign software)- I don’t see a command that finds the time of the synced units and is able to seek the single unit to the rest. Possibly a custom script could do it, but that is beyond me.
    Cliff Steinberg
    Rent Com, Inc.
    http://www.rentcom.com
    Chicago
  • Pat Ford
    November 27, 2012 at 6:57 pm
    I appreciate the information on BrightSign; it is possible that we may take that path. However, in the short run, I would like to have more information on the Adtecs. I do have twenty of them. The documentation for them is not clear…What I need is a “getting started” overview. On another thread, a person emerged who does run Adtecs SignEdje players. He invited me to email him with questions…
    However, I can’t find out how to email another member…can someone please tell me how that works?
Page 2 of 2
