Activity › Forums › Apple Final Cut Pro Legacy › Mastering SD deliverables from HD sequence
Sean Oneil replied 18 years, 7 months ago 5 Members · 16 Replies
Sean Meredith
January 26, 2008 at 11:00 pmWhat about resizing? Letterbox, anamorphic, full frame. And the PAL frame size?
BM doing the pull down. Can I do an accurate Edit to Tape that way?
-sean
Sean Meredith
Director
“Dante’s Inferno”
http://www.dantefilm.com -
Walter Biscardi
January 26, 2008 at 11:03 pm[Sean Meredith] ”
What about resizing? Letterbox, anamorphic, full frame. And the PAL frame size?”With an AJA Kona, you have all three of those options to choose from. Actually you can even lay off an HD and SD Master at the same time if you want to by downconverting one of the outputs and leaving the other at HD. Of course there’s deck control issues there, but you can do that.
[Sean Meredith] ”
BM doing the pull down. Can I do an accurate Edit to Tape that way?”With a Kona yes, no idea on BM hardware.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Jeremy Garchow
January 26, 2008 at 11:16 pm[Sean Meredith] “What about resizing? Letterbox, anamorphic, full frame. And the PAL frame size? “
You can control that in Compressor with the Geometery and Encoder tabs. Test, test, test
[Sean Meredith] “Can I do an accurate Edit to Tape that way? “
In theory, yes. Test, test, test. You will have to calculate offsets and drop frame/ndf frame rates If you need that sort of thing.
Jeremy
Sean Meredith
January 27, 2008 at 12:04 amhmmm? if the Kona card can do so much, maybe I should take to a place with a Kona card.
I notice that when I downconvert with Compressor from my HD sequence to NTSC and PAL that things that were highlights broadcast safe before can have some slight clipping. will the Kona card handle this better?
thanks for the advice!
sean
Sean Meredith
Director
“Dante’s Inferno”
Jeremy Garchow
January 27, 2008 at 12:24 amA kona will help you, yes. What you can do is make two maters, a 23.98 and a 25. The Kona will downconvert both of those in real time.
Jeremy
Sean Oneil
January 27, 2008 at 4:19 am[Jeremy Garchow] “If you have to use Compressor. I’d do an NTSC downconvert @ 23.98 and let you Blackmagic card add the pulldown on output. For the PAL version, I’d Duplicate the HD 23.98 export (self contained) and conform that to 25 fps via Cinema Tools. I would then take that HD movie and down convert in COmpressor for PAL keeping everything progressive.”
I agree with this. Keep it at 23.98 and let the BM card add the pulldown. Compressor will scale better if it’s a progressive format.
Sean
