Activity › Forums › Apple Final Cut Pro Legacy › Major FCP 7 issues.
Jason Porthouse
July 20, 2010 at 2:23 pmDitto on the file format – I got ‘codec not supported’ errors and after many hours of ‘wtf’ hair pulling, discovered I’d accidentally created a matte in CMYK as opposed to RGB. Replaced and all was well.
I’d echo the RAM thing too; the maxim ‘less is more’ is often true with FCP. My system with 8 gigs is rock solid.
Jason
_________________________________
Before you criticise a man, walk a mile in his shoes.
Then when you do criticise him, you’ll be a mile away. And have his shoes.*the artist formally known as Jaymags*
Lynette Gilbert
July 28, 2010 at 6:37 pmJust got the Error: Out of Memory message for the first time EVER today for no apparent reason (tiny 15-sec project with only 1 clip that needed rendering.) I was getting it only after trying to export as a QT file.
Thanks for the advice on copying into a new project – I was able to export after creating a brand new project. How crazy is that!
As always, Creative Cow saved my sanity once again.
Lynette Gilbert
July 29, 2010 at 9:41 pmI take it back. I just had the same thing happen, and I cannot get it to work with making a new project or restarting.
Jeremy Garchow
July 31, 2010 at 3:29 pm[Lynette Gilbert] “Just got the Error: Out of Memory message for the first time EVER today for no apparent reason (tiny 15-sec project with only 1 clip that needed rendering.) I was getting it only after trying to export as a QT file.”
What kind of file is the original? Please be as specific as possible.
Lynette Gilbert
August 1, 2010 at 3:31 pmJust a bunch of regular .mov files at 1920×1080. The projects are several 10- and 15-second commercial tags. The original files are 720×480 and were put into a 1920×1080 timeline (trust me, NOT my decision.)
I was exporting to 1920×1080, but I’d already exported similar sequences in the same project about a dozen times to the same settings without a problem.
It happened three times, and each time something different worked – once it was by making a new project (restarting didn’t work), one by simply restarting (making a new project didn’t work), and once I tried everything, none of it worked, and then on my 3rd or 4th attempt it suddenly exported.
However, when I put the files on my home computer, I had zero problems, and my home computer actually has less memory assigned to FCP than my work computer.
Jeremy Garchow
August 2, 2010 at 4:53 pm[Lynette Gilbert] “The original files are 720×480 and were put into a 1920×1080 timeline (trust me, NOT my decision.)”
Tell me more about the 720×480 files. I am not concerned at this point about what your final output is, but more of what the input file is. Most likely, that is what is causing the problem
Lynette Gilbert
August 2, 2010 at 7:19 pmThey’re just regular .mov files that I capture from my DV deck. Same files I’ve been working with for over a year. Nothing spectacular or strange about them!
