Activity › Forums › DVD Authoring › Major Amtren Flexwriter II problems
Joshua Jackson replied 11 years, 6 months ago 15 Members · 29 Replies
Trevor Bono
March 26, 2010 at 11:50 amPlease contact me I can help trevorb@medianeering.com . My company repairs other manufacturer’s equipment.
Clyde Elliott
July 30, 2010 at 7:32 pmTodd,
I’ve got one I’d like to sell. I’m not using it.
Elite 2
Model #1002-20-0000-773E2-626A7I’m in Seattle. Let me know.
Clyde
Mike Mccloskey
November 24, 2010 at 5:00 pmI have run into the same issue…each time the pick arm moves from the feeder side to the Drive side, it moves down about about 1/4 inch, therefore the sensor breaks contact with the felt pad…Im in the process of reinstalling the software to see if that helps…
Any other suggestions?
Mike
Todd Hudson
November 24, 2010 at 5:46 pmReinstalling software wont help. The gear that is used to lift and lower the arm may be some what loose. So when the arm rotates it allows the head to drop. I finally pulled mine unit apart and found this problem. I felt comfortable doing this but you have to be careful of not damaging prox switches.
Todd Hudson
Visioneering Media -
Mike Mccloskey
November 24, 2010 at 6:09 pmThat would come loose after only about 1200 DVD’s? Sheesh…can you explain what you did and I can give it a try?
Thanks for the quick reply!!
Mike
Todd Hudson
November 24, 2010 at 6:22 pmyou have to dissemble the unit, it’s not that easy to do. I have a mechanical background and didn’t hesitate taking the unit apart Mostly since it wasn’t working correctly). There are to gears attached to the shaft that raises and lowers the head. You might be able to check it by seeing if there is play in the pick up head. you shouldn’t be able to move it left or right very far. If you can the gear may be slipping.
Have a great Thanksgiving
Todd Hudson
Ned Butler
November 25, 2010 at 7:06 pmDo you know by chance what type of CD/DVD drives I can use as replacements in my Flexwriter? Any help appreciated!
Robert Burch
August 14, 2011 at 5:16 pmYou said that you hace a flexwriter unit Elite Pro 2. Do you still have and how much do you need for it. Bob
