Activity › Forums › Compression Techniques › Main Concept H.264 Issues with 23.976
Andrew Saliga replied 16 years, 4 months ago 3 Members · 12 Replies
Larry Little
April 16, 2010 at 12:19 amI agree that this difference shouldn’t be noticeable, but there is something about the way that Sorenson is removing frames that adds a slight jitter to the video.
Ah — now THAT I can understand seeing! I totally misunderstood what you were saying. I thought you were saying that it’s simply playing the same number of frames at a slightly slower speed — i.e. that the entire movie takes just a tad longer to complete. You’re saying, however, that it’s actually DROPPING frames in order to “convert” the original framerate to 23.952fps.
Yes — that’s definitely something you could see since missing frames can be quite noticeable.
If Sorenson needs a better test to demonstrate what’s happening, just give them something with timecode burn-in, or perhaps some sort of leader with even movement in it, so they can actually see the number sequence skipping over frames.
Please keep us posted on what happens,
Larry
Andrew Saliga
May 5, 2010 at 6:19 pmSorry, this has kind of been lingering. It came to my mind again today when I encountered this issue again.
Six different 30 second commercials, all 1080p, 29.97, ProResHQ. Without rhyme or reason, 3 of the 6 defaulted to various odd framerates. I had thought at time it was when using the MC H.264 encoder on content with audio and encoding with B-frames, but it seems that it’s not so predictable.
The latest I’ve from Sorenson is a major update coming out in June or July.
-Andrew Saliga
Steelehouse Productions
http://www.steelehouse.com (undergoing a much-needed redesign)
http://www.vimeo.com/steelehouse
