Activity › Forums › DaVinci Resolve › LUT for broadcast safe…..
  • Gabriele Turchi
    March 8, 2012 at 7:46 pm
    Hi Joseph ,
    Do you monitor the SDI or the exported file ?
    I am trying to understand the relationship between the gamut /video level on SDI and rendered file …
    g
    Davinci Resolve Control Surface
    MacPro
    Cubix desktop 4
    2 Red Rockets
    GTX470+GTX470+GTX285
    24GB RAM
    HP Dreamcolor
    Panasonic 58PF Plasma
  • Andrew Sableton
    March 8, 2012 at 7:50 pm
    Captioning gets done out of house here.
    I have the Tektronix WFM 5000
    I guess the issue here is the amount of throughput we have means that even though I basically manually legalize most stuff in the grading suite, we need something to catch anything missed once graphics etc are done.
    For some reason the Harris legalizer always seems to cause problems so we have given up on this. At the moment we just stick the FCP legal filter on the final quicktime before going to HDcam. It seems to work.
    AS
  • Eric Johnson
    March 8, 2012 at 8:59 pm
    What kind of problems are you having with the Harris? Which one are you using? I’ve run a ton of shows through various DL 860’s and never had a problem, that was introduced by the legalizer… on shows coming from FCP/Color/DaVinci…
Page 2 of 2
