Low audio level when recording through microphone
Bill Hadley replied 10 years, 11 months ago 8 Members · 16 Replies
Becky Blanchard
September 23, 2015 at 9:22 pmTHANK YOU SO MUCH! I have been trying to find out how to fix the low audio levels in Vegas for about an hour. It’s interesting how so many well-meaning people give vague or just plain incorrect answers. I appreciate your clear explanation. More than that, it actually worked!
Cheers, Becky -
John Rofrano
September 23, 2015 at 11:52 pmGlad that helped you out Becky. These forums are the gift that keeps on giving! lol 😀
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Welland Man
September 24, 2015 at 4:36 pmjUST GET A 2ND HAND SONY recorder use as a preamp as i had the same prob now sorted
Bill Hadley
October 8, 2015 at 12:24 amI have a USB mic that I got from Monoprice. I set it up to record in Premier and Camtasia. The recording was really great. A month later, I had to reload my computer. After setting everything up, I used the mic and the sound was very low. I’ve gone through every windows setting that I can think of and it doesn’t improve my sound. Recording sound is set to 100. have tried two other USB mics with the same issue. I have also tried the mics on another computer. No good bueno. Any ideas? The mic sounded great right before I had to reload my computer (due to a virus). Thank You!
John Rofrano
October 8, 2015 at 11:54 amMake sure that Vegas Pro is using the drivers for that Mic for recording under Options | Preferences | Audio Device.
~jr
Bill Hadley
October 8, 2015 at 6:33 pmThank You! II found the problem. All 3 of my computers have 4 USB plugs. I was using the far left one on each of them. on a whim, i decided to use the far right one and it worked. The sound was automatically better. I tried this on the other computers as well and it was the same result. I don’t know what is up with the far left USB slot, but it seems to be the problem. I wonder if this could be the problem for some of the others. I would never had thought so, but I knew at one point that it worked fine and then after thinking about it, I thought that maybe I had used the other slot before. I hope this helps others. Thank You!
