Activity › Forums › Adobe After Effects › Looking for a most effective way to do movement after the elipse
  • Jaroslaw Kaminski
    November 14, 2018 at 1:56 pm
    So do I need to split Master null or Rotating null?
    Look, I’m splitting master null, then parent layer to that splitted null layer – and animation goes even before this 5s moment.So basically it does nothing, the rotation is still provided.
    It’s the same if I’m doing it at rotating null layer, so I just got stupid right now
  • Kalleheikki Kannisto
    November 14, 2018 at 7:48 pm
    Did you change the name of the layer in the expression?
    Senior Graphic Designer
  • Jaroslaw Kaminski
    November 28, 2018 at 10:32 am
    Basically, the marked selection of rotating layer (1st do 3rd second of animation), is an example where I would like to have rotation active. In the rest of the timeline it should be inactive, but I can’t manage to do that. The rotating motion doesn’t want to stop.
    I’ve edited file that you’ve send me.
    12915_12867rotatingtoothbrushedited.7z.zip
Page 2 of 2
