Activity › Forums › Adobe Premiere Pro › Long form project suitibility
  • Marisu Fronc
    September 30, 2005 at 7:01 pm
    Mike-
    That’s not a bad workflow IF you only have a few tapes and actually want to keep all of your selects – but if you have 60 or 70 tapes, hundreds or thousands of 1st cut selects, and end up with a 60 minute programme that only uses short snippets of each selected piece you end up needing capture room (and archiving space) for MUCH more material that you actually need to.
    BTW – unlike the Media 100, you can’t batch digitize from the timeline – you need to select your “source clips” in the bin – which means you end up eating up more space than you need to even if you end up using part of most of the clips.
    I think we all agree that you CAN cut longform on Premiere, David was, originally, looking for “gotchas” that would slow down his process – hard disk space is certainly one gotcha he needs to be aware of.
    slainte,
    marisu
  • Mike Cohen
    October 1, 2005 at 5:23 pm
    Speaking of this whole issue – about 6 months ago I cut a 20 minute program. Some of the material came from DV, but some other stuff came from DVCPRO, which does not have a firewire – so I went s-video into my DV camera to get it into the computer. Thus there is no TC for that material. If I trim the project I guess it will make me new clips for the stuff I used from that material? I have kept all that raw video in the computer ever since.
    I think I’ll try trimming a smaller project first.
  • Larry Sherwood
    October 2, 2005 at 4:21 am
    One particular workflow no-no that drives me bonkers is the inability to pull a clip from the timeline to the source viewer and reuse it – you need to relocate it in the bins,
    Marisu, I just did exactly this and it seems to work fine for me. I went to the timeline, hit T for Matchframe, hit G to remove In/Out points, remarked this clip in the Source Viewer and created another edit on the timeline with different In/Out points. Is this what you were trying to do?
    LS
    Larry Sherwood
    Sherwood Post Production
    Austin, Texas
    512 219-8721
    larry@sherwoodpost.com
  • Marisu Fronc
    October 2, 2005 at 11:31 am
    Larry-
    No, not exactly – but I can do it that way if that’s what works – I simply want to drag the clip up and mark new ins & outs (no matchframe or remove In/out points – it’s the extra steps that I’d like to do without).
    slainte,
    marisu
  • Larry Sherwood
    October 2, 2005 at 4:07 pm
    There really aren’t any extra steps.
    Use the T key instead of Dragging
    You DON’T have to remove the existing In/Out, just mark new In/Out
    Press , or . to edit to timeline
    The fact that you can drag a clip to the SV from the timeline allows for very powerful and easy Slipping of a shot without needing to use Slip Mode.
    My 2 cents
    LS
    Larry Sherwood
    Austin, Texas
    512 219-8721
  • Marisu Fronc
    October 3, 2005 at 1:57 pm
    Larry-
    I know HOW to do it, but the fact of the matter is it remains a gotcha for me because I never REMEMBER to do it that way – matchframe isn’t something I think of when see a shot and have an epiphany about there perhaps being a bit on the end I could use for some trouble spot – then when I see there is, I don’t think about where I pulled the clip from and screw myself up (I always catch it, but I lose time with it, that’s why it’s my gotcha). Maybe in a few years my old brain will catch up and “remember” things like that, assuming I’m still using Premiere then, and it still works the same – ARGGHHHHH!!! Never mind, I’ll just keep repeating T not drag, T not drag (although my coworkers will probably find ominous meanings in my muttering and scurry away when I pass them in the halls!)
    slainte,
    marisu
  • Larry Sherwood
    October 3, 2005 at 6:34 pm
    I guess it’s all in the workflow approach, for me it is the same as in Edit, when I wanted to use a clip from the timeline as a source in the source viewer I always used the Matchframe keyboard command to load the clip to the source viewer so the workflow for me is the same.
    LS
    Larry Sherwood
    Austin, Texas
    512 219-8721
Page 2 of 2
