Activity Forums Apple Final Cut Pro Legacy Livetype under 6.0.3
  • Mitch Ives
    April 22, 2008 at 9:53 pm
    So much for the theory that my 8800 card might be the culprit. Thanks for narrowing that down… I’ll look in other areas now…
    Mitch Ives
    Insight Productions Corp.
    mitch@insightproductions.com
  • Steve Cohen
    June 12, 2008 at 12:33 pm
    Ok, what I’ve come to fine out through my own trials and those of another in my area is that this is not a QT Issue, it’s not a Live Type issue, it’s not a Mac Intel 8 Core issue, but it is a Blackmagic issue.
    You’re posts don’t mention it, but I’m guessing that you have a Black Magic card or box or some kind of I/O device from them.
    I can’t remember what causes it or how to fix it, but I think if you remove the BlackMagic Codec.component from the Quicktime Library when you use Live Type and rendwer out a QT of the graphic and then put it back when you are done that will give you a work around.
    The other option that I and others did was to goe back to FCP 6.0.2 and QT 7.4.1
    Steve Cohen
    Editor
    O2 Media Inc.
  • Lawrence Gray
    August 15, 2008 at 6:51 am
    Hm, I was just thinking this sounds like my problem… then you said it was something to do with Blackmagic. I haven’t got any card in my machine. .ipr files just give me a blank screen in FC. I can render to .mov and import that and it’s OK. But not the .ipr file.
    Hardware Overview:
    Model Name: Mac Pro
    Model Identifier: MacPro3,1
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 2.8 GHz
    Number Of Processors: 2
    Total Number Of Cores: 8
    L2 Cache (per processor): 12 MB
    Memory: 8 GB
    Bus Speed: 1.6 GHz
    Boot ROM Version: MP31.006C.B05
    SMC Version: 1.25f4
    Serial Number: YM8170CTXYL
    Lawrence Gray
  • Steve Cohen
    August 15, 2008 at 4:09 pm
    Yeah, my experience and those that I’ve talked to with the same problem were all on Intel Octocore Systems with BlackMagic capture devices.
    BlackMagic updated thier drivers and it has been fine since.
    I would try updating to the current version of QuickTime (7.5 I think) and Final Cut 6.0.4 (Part of a Pro Apps Update).
    Steve Cohen
    Editor
    O2 Media Inc.
Page 2 of 2
