Activity › Forums › Compression Techniques › live webcast needs
Craig Seeman
June 21, 2010 at 7:40 pmThe Roller Derby track is 88′ announcer area was past one end and the TD area (Wirecast computer) was at the other so it was around 100′ for the longest cable/repeater run.
You can get a sense of camera placement here although you might need to go in about 30 minutes for the start. I believe two cameras were within 20′ or so but one was arena and the other at the other end showing the backs of the jammers when they lineup. Basically one corner has one camera. The other corner near the gear has two and another mid arena.
https://www.justin.tv/gothamgirlsrollerderby/b/265175384 -
Rich Rubasch
June 22, 2010 at 12:40 amMediaSite Live by Sonic Foundry is a truly portable and live video switching solution. Have a look at it…it is a truly hardware based robust tried and true industry standard. Nothing else is close.
Rich Rubasch
Tilt Media Inc.
Video Production and Post
Owner/President/Editor/Designer/Animator
https://www.tiltmedia.com
