Activity › Forums › Adobe Photoshop › Line work in photoshop
  • Airbrush Art
    April 2, 2007 at 11:32 am
    No Maybe this is the problem ,I do not want my line turn into a negative shape.
    All I asked was how do you take the white background out of a line drawing that has been scanned so that if I want to put a color on a different layer ,it will show through so that the line art is sitting on a colored background instead of white.
    Lets forget it . An art director of mine gave me the easy solution which I described in the earlier messages.
    Thanks for the help.
  • Matt Shadis
    April 12, 2007 at 6:01 pm
    ok, I know you gave up but there is a way easier way to do all of this, it’s a feature of Photoshop that many people don’t seem to know about and is made just for your case.
    Take the line art layer and place it above the gradient layer.
    Double click to the right of the line art layers name in the layers palette, just that blank white space that is there. This will open Layer Styles.
    In the layer styles dialog you should be on the section labeled ‘Blending Options:Default’. If not, just click there in the left column.
    In that portion of the dialog at the bottom there is a section labeled ‘Blend If: Gray’ below this are two sliders.
    In the first slider (labeled ‘This Layer’) grab the white triangle and move it to the left.
    Poof! All the white is now transparent. You may have some gray around the edges of your line art so hold down the Option key (Alt on a PC) and grab that same white triangle again, now it will break into two parts. Adjust these as needed until your lines look smooth and contain only the parts you want.
    Some levels may help here as well if you can’t get any of the fringing off, just eliminate the white in levels and you should be cool.
    Hope this helps.
    -Matt
  • Vincent Rosati
    April 12, 2007 at 7:47 pm
    THX. I wasn’t aware of that. : )
  • Scott Butzer
    November 1, 2010 at 7:34 pm
    Grey scale/or rgb
    Channels-top bar-grey: command select layer
    Go back to normal layers
    Create new layer
    Invert
    Fill with color
    My bro sent me this, and so long as the line work is solid (ink) this works like a charm.
Page 2 of 2
