Activity › Forums › Apple Final Cut Pro › Libraries vs Events
  • Mark Suszko
    October 8, 2015 at 2:34 pm
    I have gotten very stern and scary warnings from FCPS about sharing between libraries. And they seem to be valid, because when I get into trouble, that’s one of the root causes for it, apparently.
  • James Ewart
    October 8, 2015 at 2:42 pm
    [Mark Suszko] ” have gotten very stern and scary warnings from FCPS about sharing between libraries. And they seem to be valid, because when I get into trouble, that’s one of the root causes for it, apparently.”
    Thanks for the warning.
    I always tend to copy back the event from the newer library into the main backup library before using stuff.
    But it’s goof to have one’s card marked to deter me from getting lazy some day!
  • Doug Metz
    October 8, 2015 at 3:00 pm
    [Craig Alan] “how [could] the media (without using aliases) be in both libraries but not double the space”
    Think of the hard disk as a shed next to your house, and in that shed is a ladder (your data).
    In this situation, an alias would be a sign at the end of the driveway with a picture of the ladder and an arrow pointing toward the shed. A hard link would be adding another door to the shed, so you can access the same ladder from two different entrances. Sealing up a second door doesn’t change the ladder.
    When you create a copy with the Finder, it goes down to Home Depot and buys another ladder to put in the shed.
    FCPX opens new doors when you copy media from one Library to another on the same drive.
    At least, that’s how I understand it…
    Doug Metz
    Anode
Page 2 of 2
