Activity › Forums › Compression Techniques › Large Volume Format Conversion
  • Chris Blair
    August 21, 2009 at 2:23 pm
    In this particular case, it was a known and admitted bug within the Windows version of Handbrake and not Windows related. So this had nothing to do with Windows. Also..since Handbrake is open source, it took a really long time for the people that volunteer their time to address the problem and fix it.
    Anyway…we’re a PC shop with 5 high-end NLE workstations and I can count on one hand the number of crashes we have per month. We leave them running 24/7 and can sometimes go weeks without rebooting while running a multitude of software and hardware based apps. So I think it really depends on how a PC shop’s computers are setup and maintained. Conversely I worked in a College a few years ago that was all Mac (with the highest-end Mac workstations at the time) and we couldn’t work for 2 hours without a crash.
    Don’t get me wrong…Mac’s are great…well engineered, solid OS. But Windows PCs get a really bad rap simply because there are so many boneheads that load 500 software apps on a system that’s designed to pump out work every day. Or they build a PC as cheaply as they can and expect it to churn out workstation class performance.
    Spend as much on a Windows PC as you spend on a MAC, set it up properly and it will run solidly for years.
    But yes… Handbrake is a nice little program for H264 output.
    Chris Blair
    Magnetic Image, Inc.
    Evansville, IN
    http://www.videomi.com
  • Daniel Low
    August 21, 2009 at 2:55 pm
    [Chris Blair] “Spend as much on a Windows PC as you spend on a MAC, set it up properly and it will run solidly for years. “
    I’ll probably get accused of trolling and sorry for hijacking the thread, but what’s the point of spending as much on a PC as you do on a Mac (notice it’s not uppercase) and then spending loads of time getting it setup just right when you could just get a Mac that is set up perfectly out of the box, and then run Windows on it? It’s a well known fact that Apple makes the best Windows PC.
    Windows PCs get a bad rap simply because of Windows:
    https://www.brandonwalkin.com/blog/2009/08/10/managing-ui-complexity/
    https://mossblog.allthingsd.com/files/2009/08/windows-upgrade-chart.png
    https://coolinfographics.blogspot.com/2009/08/mac-os-x-snow-leopard-upgrade-chart.html
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today
  • Craig Seeman
    August 21, 2009 at 3:52 pm
    Episode handles VOB source. I just tested it.
  • Chris Babbitt
    August 21, 2009 at 4:06 pm
    That’s great news. I didn’t see that listed on their web site. How long did it take?
  • Chris Babbitt
    August 21, 2009 at 5:42 pm
    I downloaded Handbrake (V. .9.1. because I’m still on OS 10.4) and I encoded a 40 min. VOB file in 18 minutes compared to 25 minutes using Mpeg Streamclip, and it looked slightly better as well. I’m still looking for faster solutions, since I have 60 hours of material to encode.
  • Daniel Low
    August 21, 2009 at 5:56 pm
    What settings did you use? Some of the advanced settings can increase times massively for not much increase in picture quality.
  • Chris Babbitt
    August 21, 2009 at 6:07 pm
    I set the bit-rate to 800 kbs, since that’s the bit-rate it will be streamed at. I also changed the audio to mono, and the aspect ratio. Some set-top DVD recorders use an oddball type of anamorphic scheme, which results in a 704×480 video, so I had to uncheck the anamorphic box which corrects it to 640 x 480.
  • Daniel Low
    August 21, 2009 at 11:02 pm
    I was referring to the advanced settings like:
    Motion estimation method and range
    Sub pixel Motion estimation size
    Number of ref frames and b frames
    CABAC or CAVLC
    etc
  • Chris Babbitt
    August 21, 2009 at 11:27 pm
    No, I only changed the stuff I mentioned.
  • Daniel Low
    August 22, 2009 at 12:08 am
    You could be working with unnecessarily high (advanced) settings, try knocking them down a bit.
Page 3 of 3
