Laging in preview-mode even with 4K Computer!
Wayne Waag replied 10 years, 10 months ago 3 Members · 26 Replies
Sep Nolia
November 2, 2015 at 10:33 pmThank you all for the answers!
But I can’t test your ideas anymore … =/Someone suggested me to update my BIOS to solve this problem.
I downloaded the latest BIOS-Driver for my asus x99-a mainboard and installed it.
I had to wait a few secs and when it was done it restarted the computer.
Afterwards I had no screen and the LED thing on my mainboard turned to “99”.It’s broken now =/
I have to send the mainboard back …
Aaron Star
November 2, 2015 at 10:44 pmwow that sucks man. Bios is normally a pretty easy to upgrade, what with manufacturer update apps and stuff now. Might be for the best, if you installed the correct BIOS, maybe there was something else wrong with the board if it failed.
Post again when you get back up, would like to know how things turn out.
Wayne Waag
November 2, 2015 at 11:00 pmThat’s really terrible. What a bummer! Hopefully, you still have your old system to carry on till you get the new one up and running again. Good luck.
wwaag
Sep Nolia
November 2, 2015 at 11:06 pmThank you guys really!
Well yea that scks much =/
I hope they will send me the new mainboard as soon as possible. -
Sep Nolia
November 10, 2015 at 5:10 pmHello my dear internet friends!
I have finally recived my new motherboard .. I had so much trouble with the company getting a new one…
At first they send me my old one back so I had to wait another week to get the new one.
Whatever at least I got it now! 🙂@Wayne Waag & Aaron Star
“In any case, make sure that your project settings are the same as your GoPro footage.”
“If you are trying to create 1080-60P material, your project settings frame rate should be 1920×1080-59.94 Progressive. You can use the Match media Icon Button in the upper right corner to match your project to the source material.”https://www.directupload.net/file/d/4167/u8g2m4ea_png.htm
Thank You!
After I have clicked on yes it doesn’t lag anymore if I want to preview the video in vegas on “Best-full”
(CPU on 15%)But it starts lagging again if I put just one effect inside the video =/
For example the “Glitzen effect” It even lags on “Draft-Quarter” (CPU almost on 100% again, even on draft-quarter)@Aaron Star
“make sure your GPU is selected under Options>Preferences”
-It is selected.Here are some GPU-Z pictures:
–https://www.directupload.net/file/d/4167/egckzl35_png.htm (Graphic-card first tab)
–https://www.directupload.net/file/d/4167/g72i82wu_png.htm (Render test)
–https://www.directupload.net/file/d/4167/ddqhhqfw_png.htm (Bus Interface … It says the graphiccard is on PCI-Express x4 v.1.1 right now. Maybe that’s the whole Problem !? I don’t have much experience about Hardware. I don’t know what it means)–https://www.directupload.net/file/d/4167/vgsu9d23_png.htm (this is what I get on “best-full” without “glitzer effect”)
–https://www.directupload.net/file/d/4167/qx974tbo_png.htm (this is what I get on “draft-quarter”without “glitzer effect”)
–https://www.directupload.net/file/d/4167/y45chgj9_png.htm (this is what I get on “draft-quarter” with glitzer-effect) The values of these 3 aren’t changing just the red-bar. Maybe I forgot to click on something to start the process?——————————————-
Here are the speccy-pictures:
M.2 SSD: https://www.directupload.net/file/d/4167/jsstwkkk_png.htm
DDR 4 2666 Ram: https://www.directupload.net/file/d/4167/3renuzgu_png.htm (weird .. it just shows 1333mhz frequenzy instead of 2666 mhz)
graphic card: https://www.directupload.net/file/d/4167/8k28rnyo_png.htm
motherboard: https://www.directupload.net/file/d/4167/4fdy56ac_png.htm -
Aaron Star
November 10, 2015 at 8:48 pmMy question on the x16 GPU issue. Is the GPU installed in the PCIe slot closest to your CPU, or is it installed in the slot furthest away from the CPU. The 2 slots nearest the CPU should be x16 capable on an x99 board, meaning you should be able to run dual GPUs at full speed.
Could you post a photo of how you have your boards installed into the motherboard? Board placement for accessory boards is sort of important, so that you do not impede the GPU bandwidth.
x4 v1.1 is like 1GB/s when you should be getting 16GB/s through to the board.
Sep Nolia
November 10, 2015 at 9:06 pmYes it is installed in the PCie slot closses to the CPU.
https://www.bilder-upload.eu/show.php?file=d1009a-1447190121.jpg
https://www.bilder-upload.eu/show.php?file=cff6bd-1447190084.jpg
https://www.bilder-upload.eu/show.php?file=a3422e-1447190118.jpg
https://www.bilder-upload.eu/show.php?file=c889fc-1447190123.jpg
https://www.bilder-upload.eu/show.php?file=96d154-1447190061.jpg
(You have to zoom out to see the whole picture)
I connected all my fans on the mainboard instead to the powersuply. Maybe that’s the problem.by the way look at this.
I just noticed this in my bios.
https://www.directupload.net/file/d/4167/ar8449bh_jpg.htm
https://www.directupload.net/file/d/4167/44jz7pzg_jpg.htm
It says “NO VGA Card”. =/ -
Aaron Star
November 10, 2015 at 9:31 pmSince you have no other boards installed, you may need to contact ASUS and ask them what that means. It could also be a bug in GPU-z not correctly understanding the x99 board. It’s hard to say what the issues really is. Have you check the motherboard manual for that X4 or Auto settings? I would think AUTO would work with such new hardware on both the MB and GPU.
I also have to correct my multi GPU statement. Depending on the 59xx series CPU you have, you may be able to run 2x GPUs at 16x speed. If you have the 59xx series CPU with only 28 lanes, obviously you can run only 1 GPU at 16 lanes speed. This should not really factor into what we are troubleshooting because you only have one card.
Sep Nolia
November 10, 2015 at 9:41 pm“Have you check the motherboard manual for that X4 or Auto settings? I would think AUTO would work with such new hardware on both the MB and GPU.”
I can’t find anything about it it the manual.But if I want to change to X4 in the BIOS.
It says:
[Auto:] Disable PCIEX16_4 Slot when a M.2 device is detected.
[X4 Mode]: Run at X4 mode for high performance support with m.2 Disabled.
And If I do this I can’t boot to Win 7 anymore. It won’t regocnize the M.2 in X4 Mode -
Sep Nolia
November 10, 2015 at 10:44 pmDo you think this graphic-card (pci-express) problem causes my lags?
