Activity › Forums › AJA Video Systems › Kona LHi, FCP & 720p
  • Jeremy Garchow
    January 18, 2011 at 6:23 pm
    [dan luke] “The problem occurs when I playback a clip in the viewer so not a whole lot of settings to consider.”
    Well, but there is. If FCP is in a different mode than 59.94 and you material playing back is 59.94, the clip and the video output settings won’t match.
    Jeremy
  • Dan Luke
    January 18, 2011 at 6:47 pm
    You mean the playback output settings in the A/V Device tab of the audio/video settings menu? I really only have 2 viable alternatives. Either 8 or 10 bit 720 59.94. Any other setting won’t playback or is an unsupported signal for my monitor. 720 8bit or 10bit exhibits the same behavior.
  • Jeremy Garchow
    January 18, 2011 at 6:50 pm
    It’s really easy, Duke.
    Hit control-q, select AJA Kona LHi 720p 59.94 ProRes as the easy setup and make a new sequence.
    Load clip in to viewer, play.
    Try loading that same clip in to a timeline and play.
    What do you see?
    Jeremy
  • Dan Luke
    January 18, 2011 at 6:54 pm
    a stuttering clip trying to playback on my external monitor and my viewer window
  • Jeremy Garchow
    January 18, 2011 at 6:55 pm
    Then perhaps there is something wrong with the clip. 720p59.94 clips play just fine here on the LHi we have.
    Where did these clips come from?
  • Dan Luke
    January 18, 2011 at 7:05 pm
    They’re Ki-Pro clips data rate around 17 MB/sec. What kind of data rates do you have? The rates for other clips in this project are pro-res clips converted from HDV tape over firewire 23.98 fps and the data rate is around 7 MB/sec.
  • Jeremy Garchow
    January 18, 2011 at 7:13 pm
    For 720p59.94 clips, that is the neighborhood of data rate, for sure. ProRes is VBR so it will fluctuate a little bit.
    HDV is much smaller than ProRes.
    Any chance you can upload a small/short full res sample of the KiPro capture?
  • Dan Luke
    January 18, 2011 at 8:08 pm
    I’ve uploaded a 345meg sample clip. I have confirmed that this clip has the same playback problems as the other 59.94 fps clips.
    ftp://hwpics.com/sample/
  • Jeremy Garchow
    January 18, 2011 at 8:26 pm
    Thanks so much. This will help and downloading now.
    Jeremy
  • Bob Zelin
    January 18, 2011 at 10:11 pm
    this whole thing is insane. You should be able to playback a single stream of ProRes422 or DVCProHD right from your boot drive. Something is very wrong with your system.
    For your Xserve RAID –
    open RAID Admin (you do have RAID admin, right ?)
    click on Setttings> Performance
    under performance, click this for EACH SET of drives –
    Disk Drive Cache – enable (check this box)
    Allow Flush – disable (uncheck this box)
    Streaming – disable (uncheck this box)
    Read Prefetch – 8 stripe (this is in the middle window).
    OK, now for your computer – you did not say what type of MAC this is – is this an early MAC Pro ? Is it a Model 1,1 version that uses Expansion Slot Utility ? Open up Expansion Slot Utility (do you know how to do that), and MAKE SURE that NOTHING is in a x1 slot. The XServe RAID is old, so I am guessing that your Mac Pro is old. The AJA Kona card AND the Apple Fibre card CANNOT BE in a x1 slot.
    If you are unsure, check the bottom (4th) selection, which will give you x4 x4 x8 x8, so you can properly test your system.
    when doing tests, ALWAYS start with a new project, go into EASY SETUPS, select what you want (like HD, DVCProHD, 59.94) and once the project opens, open up a NEW SEQUENCE. Then import your KiPro media, and do your test.
    Let me know.
    bob Zelin
Page 2 of 3
