Activity Forums AJA Video Systems Kona LHe, MASSIVE video drift!
  • Bob Pierce
    April 12, 2012 at 12:50 pm
    The solution for me was to change the output (in audio visual settings) to Kona 8 bit, rather than the 10 bit as used by the default Kona easy setup. This solves the problem for me, and as far as I can tell has no negative effect on image quality. I created custom easy setups so I don’t have to change it every time I change the setup. Hope this helps.
    Bob
    Director of Photography • Editor
    http://www.lightstreamassociates.com
  • Scott Elliott
    October 27, 2012 at 12:43 am
    Hey all,
    I know this is a few months on, but if anyone else is having this problem on newer Mac Pros (post expansion slot utility), the Kona LHe MUST be in either PCIe slot 1 or 2.
    I was having seriously annoying sync and drift issues after getting a new Mac Pro* and realized I had installed the card in slot 3. Once I swapped it into slot 2, everything is running perfectly.
    I was worried that Mountain Lion killed the Kona LHe or FCP 7.03, but everything is running smooth as butter (except for banding on my 23 in cinema display, but I don’t really care cause my Flanders Scientific LM-1760W looks so beautiful it hurts..)
    Scott
    https://www.590films.org
    https://www.faithinthefiveboroughs.org
    *Mid 2012
    Processor 2.8 GHz Quad-Core Intel Xeon
    Memory 13 GB 1066 MHz DDR3 ECC
    Graphics ATI Radeon HD 5770 1024 MB
    Software OS X 10.8.2 (12C60)
Page 2 of 2
