Activity › Forums › AJA Video Systems › Kona 3 HD Downconvert doesn’t look very good???
Capturedlive replied 20 years, 5 months ago 8 Members · 17 Replies
Aja Sales department
April 29, 2006 at 9:53 pmHi,
Have you tried to contact AJA tech Support? We would be more tha happy to help.
Thank you,
AJA Video Systems
(530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com -
Capturedlive
April 30, 2006 at 2:48 amI will call you guys as soon as we ship the DLT on this project. I simply didn’t have time to figure this out for this project but I’m very curious to figure out what the issue is. Thanks.
Producer / Technical Supervisor
Captured Live Productions
http://www.caplive.com -
Walter Biscardi
April 30, 2006 at 3:39 pm[CapturedLive] “Anyone have any valid theories?”
I would do what Bob Zelin suggested and get somebody in your shop or call AJA Tech Support to find out what is going on. Downconvert is a very straightforward thing with everthing happening in the card. In 2 years of running the K2 I’ve never seen anything like that no matter what the originated footage.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Capturedlive
April 30, 2006 at 9:06 pmDoes anyone in the LA area have a system set up with a HD/SD switchable broadcast monitor and a Kona3 I could bring our DVCPROHD file over to and check it out? Let me know, and what you’d charge me. Thanks. If you have a Digibeta deck all the better so I can compare our output from Sunset Digital with what the Kona can do. Thanks.
-Evan
Tony
May 1, 2006 at 6:59 amI wonder if the problems you describe have anything to do with your viewing monitor. Depending on how it was calibrated and the model of the monitor used you will get vastly different results compared to what Sunset is using in their bays with the aid and support of a full time engineering staff.
HDV is 4:2:0 so I would expect to see some bad chroma artifacts after multiple generations.
Tony Salgado
Gary Adcock
May 1, 2006 at 3:24 pmI’m going to jump in the fray backing both Walter and Bob,
I have not seen any issues with the Down-convert from any of the Kona Boards, Walter and I both were amazed at the quality of the NAB 2K demo being shown at HD and NTSC rez with virtually no loss.
you are not trying to go to PAL are you???
you have checked your Kona Control Panel to make sure everything is correct?
did you check the cabling? ( and change them just to be safe)Studio37
HD & Film Consultation
Chicago, IL
gary@studio37.com -
Capturedlive
May 1, 2006 at 9:25 pmThe footage was shot DVCPROHD straight to disk from the HDSDI out of the XLH1. No HDV involved…
