Activity › Forums › AJA Video Systems › Ki Pro Playback From Transfered Video
Elliott Balsley replied 13 years, 9 months ago 7 Members · 13 Replies
Aja Sales department
March 10, 2011 at 7:30 pmJason, Jeremy and Brendan,
In order to help clarify the creation of QuickTime files with appropriate audio for use with Ki Pro, here are some basic guidelines for your consideration.For the Final Cut Pro Sequence Settings, and within the General tab, the Audio Settings should be configured for:
Rate: 48 kHz
Depth: 24-bit
Config: Channel GroupedFor the Sequence Settings, and within the Audio Outputs tab, the Grouping should be set for Dual Mono.
For a QuickTime Movie output, select the Sequence with the in to out points, and then select File>Export>QuickTime Movie. The Save prompt will appear and it should be noted that the default is for the Setting selection to be Current Settings, Include Audio and Video and Make Movie Self-Contained with the checkbox selected. Select OK to save the file. Remember that to be visible to the AJA Ki Pro, an Apple ProRes 422 QuickTime file needs to be placed within the Ki Pro folder named “AJA.”
Using this method should produce a valid QuickTime movie file for use with the Ki Pro if the Sequence Settings are also appropriately configured. Remember that in addition to the audio settings noted, the video needs to be acceptable full-raster Apple ProRes 422 (Proxy), Apple ProRes 422 (LT), Apple ProRes 422 or Apple ProRes 422 (HQ).
Another QuickTime Movie output option from Final Cut Pro is to select the appropriate Sequence with in to out points, and then select File>Export>Using QuickTime Conversion.
When the prompt appears, the QuickTime Movie should be selected for Format. Click on the Options… button to configure. For the Video portion, select Settings…
Choose the appropriate Compression Type – Apple ProRes 422 (Proxy), Apple ProRes 422 (LT), Apple ProRes 422 or Apple ProRes 422 (HQ).
In the Motion area, set the frame rate to what is appropriate for your movie, such as 29.97 fps.
In the Compressor, if the material is interlaced (such as 1080i or SD), select the Interlaced checkbox. If you are in a 60Hz region, HD interlaced material will be Top field first for the pulldown selection and SD interlaced material will be Bottom field first. You can select OK for this section and move on to Size… from the Video settings.
Size is determined by your Sequence material and the Size selections provide pre-determined selections for NTSC, PAL and HD raster sizes within the list. Select the one that is appropriate for your material. You can select OK and move on to Sound settings.
Sound Settings should be as follows:
Format: Linear PCM
Channels: Stereo (L R) or 2 Discrete Channels (either is acceptable)
Rate: 48.000 kHz
Render Settings: Best
Linear PCM Settings, Sample size: 24 bits, Little Endian checkbox selected.
Once these selections are made, hit OK.Hit OK once again in the Movie Settings prompt. You should be returned to the Save window. Save to the desired location. Again, remember that to be visible to the AJA Ki Pro, an Apple ProRes 422 QuickTime file needs to be placed in the Ki Pro folder named “AJA.”
If you need any assistance with this or any other matter, AJA Technical Support will be happy to help. You can contact them free of charge via email or phone.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com -
Mark Rule
March 11, 2011 at 7:12 am[Jeremy Garchow] “What firmware are you guys running?”
Firmware is 2.0.0.125
Elliott Balsley
December 7, 2012 at 9:09 pmMuch thanks to Aja for posting those detailed instructions. I couldn’t find that info anywhere else. Another thing that I learned is to pay close attention to the KiPro supported formats in the manual. For example, I nearly went mad before realizing it can’t play 1280×720 at 30fps. So I had to upres my clips to 1080 and then it worked.
