Activity Forums VEGAS Pro jumpy footage
  • Eric Clinch
    July 26, 2017 at 4:05 am
    I’ve been researching more into the ‘should OIS be on or off on a tripod’ question.
    Most of the comments around the net relate to still camera shooting where the need for stabilisation is different to video. The need with stills is to freeze any camera movement at the instance the shutter ‘fires’. With video, shots are continuously being taken and our need is to keep the subject continuously steady in the frame. Both my current Canon and previous Panasonic tape camera recommended switching OIS off when using a tripod. But my own tests have given no image difference between On and Off. Most of my tripod work is closeups but I’ve just carefully studied a recent video I made of local scenes using a tripod for many of the shots. Looking at the image edge on my TV for signs of movement I detect none other then when my tripod was clearly being buffeted by wind. Had I had OIS off I expect the movement caused by wind may have been worse. So I’m keeping mine on.
    This doesn’t help the OP. I wonder whether the jumps are caused by tripod movement resulting from vibration. Mention is made of wooden floors and bass frequencies. Possibly there may have been jumps whether OIS was on or off. Only comparison tests under similar circumstances will show which was better – OIS on or off.
  • Francois Pénzes
    July 29, 2017 at 10:37 pm
    Hi Ross
    Eric C. is on to something here.
    I’ve analyzed your second clip and the jitters match the bass in the auditorium.
    I would try to find a similar environment and do some test record using different settings. Stab. on, stab. off, etc… in order to find the optimum setting for your camera.
    If possible, send me a link to your original footage. (Dropbox, etc…) A 20 sec. clip will do. I’ll see if I can help you save that footage.
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
    Cameras: Canon XF305 + Canon XH-A1
    \’\’When the cutting stops, the editing begins…\’\’
Page 2 of 2
