Activity › Forums › Apple Final Cut Pro Legacy › Jpeg photo moves are bad-jaggy, stairstepped
Tom Brooks replied 19 years, 2 months ago 4 Members · 12 Replies
Ed Cilley
July 9, 2007 at 4:08 pmSOLVED!
So, I tried several of the suggestions from the posting here, the results were always the same (or worse), jaggy edges.
I finally started trying small renders and viewing the original QT file. When I turned off “Use Open GL Renderer” in After Effects, the images were sharp and clean. I went back to some original settings, 720×480, lower field, Animation Codec, NO Open GL Renderer, and tried again. Nice sharp edges.
I am using an Intel MacBook Pro, with AE 7.0. I turned down the amount of RAM usage that AE is allowed to use and solved the other problem I was having–crashes. Life is good.
Thanks for your help.
Tom Brooks
July 10, 2007 at 12:51 pmThanks for the followup. Don’t know that much about OpenGL renders. I thought it was more for rendering previews instead of output. It’s impossible to keep up with all the ins and outs!
