Activity Forums Apple Final Cut Pro Legacy Is this system powerful enough?
  • Is this system powerful enough?
    Posted by Chris Burton on June 2, 2005 at 8:48 am
    I’m just getting started with editing on a PowerMac, and am just looking for a second opinion on whether this system is going to be powerful enough:
    PowerMac G5 Dual 2.3 GHz processor
    ATI Radeon 9650 256MB DDR SDRAM
    250 GB Serial ATA
    2x1GB RAM
    16x SuperDrive
    Bluetooth Module & Airport Extreme Card
    23″ HD Display
    AppleCare Protection Plan
    Final Cut Studio
    I just need to know if I’m making any glaringly obvious mistakes hardware-wise, and would appreciate some advice.
    Many thanks in advance,
    Chris Burton
    Mitchji replied 21 years, 3 months ago 8 Members · 11 Replies
  • 11 Replies
  • Peter Wiggins
    June 2, 2005 at 9:50 am
    Chris,
    What format are you going to be cutting, DV? SD?
    Peter
    https://www.peterwiggins.com
    In Paris editing The French Open for ESPN
  • Chris Burton
    June 2, 2005 at 9:56 am
    DV and then, eventually, SD.
  • Alexander Kallas
    June 2, 2005 at 10:07 am
    Chris,
    You really need more RAM, 1.5G is the minimum for these apps.
    Alexander
  • Chris Burton
    June 2, 2005 at 10:13 am
    Alexander,
    Thanks for the reply.
    Does that mean that I need to have 1.5 GB or more in each processor?
  • Alexander Kallas
    June 2, 2005 at 10:21 am
    Chris,
    1.5G is an overall RAM figure.
    Cheers
    Alexander
  • Joachim Blunck
    June 2, 2005 at 10:30 am
    Looks like he has 2GB in his configuration…
    Plenty for DV, perhaps a little light for serious SD.
  • Phillip Van west
    June 2, 2005 at 1:57 pm
    You will most definitely need more storage, as you don’t want to capture to your startup drive, so I would first add a Hitachi 250GB or 400GB drive as your second internal SATA drive and capture to that. As you progress to more demanding transfer rates, an external SATA drive setup would be one way to go.
    pvw
    Terra Nova Productions LLC
    G5 DP 2.5GHz / 4.5 GB RAM / 2x250GB SATA / OS 10.3.9 / FCP 4.5 / QT 6.5.2
  • Mrvideo
    June 2, 2005 at 3:46 pm
    Final Cut Pro 5 can access up to 4 Gigs of RAM so the more you have up to 4 Gigs is going to be very helpful. Your 2.3 GHz is faster than the 2.0 GHz G5 that everyone is using so you should be fine.
  • Mitchji
    June 2, 2005 at 5:06 pm
    With the current models the 2.3 is a good choice (PCI-X and 8 RAM slots).
    You can save some money by ordering the RAM from Crucial.com. I wouldn’t even dream about buying additional RAM from Apple.
    If you are sure you won’t want to go over 4 Gigs you could add 4 one half gig chips instead of 2 one gig chips. This will cost substantially less but will fill more slots (you will still have two free slots).
    Best Wishes,
    Mitch
  • Peter
    June 2, 2005 at 7:00 pm
    “With the current models the 2.3 is a good choice (PCI-X and 8 RAM slots)”
    Does the 2.7 have PCI-X and 8 RAM slots as well?
    Also, what graphic card would someone recomend at this point for top-of-the-line performance with FCP 5 and a Decklink HD plus card. With the NVIDIA GeForce 6800 Ultra DDL taking up an extra PCI or PCI-X slot, will that severly limit my options for maximizing performace with Decklink and a SCSI or Fibre Channel card?
    How different is the performance of the NVIDIA GeForce 6800 Ultra DDL from the ATI Radeon 9650 w/256MB DDR SDRAM?
    Or should I go for the ATI Radeon 9650 w/256MB DDR SDRAM from the apple store and replace it with a ATI 800X?
    Sorry for all the questions but the graphics card choices have me extremely confused!!!
    Thanks in advance.
