Activity › Forums › Avid Media Composer › Is native prores stable enough to edit feature film? Or should we go dnxhd?
Christian Hart replied 12 years, 8 months ago 16 Members · 47 Replies
Toke Trangbæk
February 26, 2012 at 5:03 amOk i get it and i hear what you are saying in this scenario.
But i would really just like to hear from somebody that have worked with native prores in Avid 6 on a big project.
Let’s say i have a documentary – 300 hours – prores – it was planned to edit in fcp – but the producer now wanna change to Avid… Will Avid 6 new native prores feature be solid enough to dó this?
Shane Ross
February 26, 2012 at 8:23 amThe likelyhood that someone, in the very short time that MC6 has been out (2-3 months), has used MC6 for this specific workflow, AND who frequents these forums…is mighty slim. You might, indeed, be the first. There might be people who did short projects, but not long ones.
And Michael…If you AMA, then transcode, that is a FAST IMPORT as well.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Job Ter burg
February 26, 2012 at 8:35 amMichael, I thought you could AMA-link to a ProRes file, then not Transcode but rather Consolidate, and that this would be a re-wrap rather than a retranscode.
Job Ter burg
February 26, 2012 at 8:37 amI don’t think you should transcode but consolidate then, Shane.
Michael Phillips
February 26, 2012 at 2:32 pmUnless something changed in 6.0.1, I was told that the rewrap was done as part of the “fast import” process. During beta I entered a bug that my ProRes was being transcoded with AMA, and that was the response I got. I agree that an AMA “consolidate” logically, that’s how it should work. I will try to test it again today. I would be glad to stand corrected.
Michael
Michael Phillips
Michael Phillips
February 26, 2012 at 4:00 pmQuick test under 6.0.1 on Windows 7. I understand the fact that it doesn’t allow for Prores encoding… but since the incoming file is ProRes (HQ), the rewrap process should not invoke an encode process.
1. AMA to ProRes(HQ) file. Plays back fine. Highlight and click on consolidate/transcode. Go through first screen of settings, then second about linking master clips to target drive. Click OK. Get message to check error message in console. Lots of info about how codec being read not supporting, resorting to sample player. So no rewrap “copy” of ProRes file to Avid managed media. Logically, this would be the way to do it.
2. Since there is no encode on Windows 7, the “fast import” was not even a choice since I could not select ProRes(HQ) as a target resolution. Dead end.
So it seems, unless I am missing a step, that ProRes on Windows is AMA playback only. Select alternative codec (DNxHD) for render and/or transcodes. I will need to get a v6 on my Mac to test there.
Michael
Michael Phillips
Shane Ross
February 26, 2012 at 6:14 pmYes, Windows machines have ProRes playback only…cannot encode or transcode to ProRes.
And I was told that AMA then Transcode was a FAST IMPORT. I THOUGHT I was anyway…could be that the CONSOLIDATE feature is the fast import. But I swear it was the transcode option.
Shane
Little Frog Post
Michael Phillips
February 26, 2012 at 7:08 pmLogically a “consolidate” is only a copy/rewrap to Avid managed media, but does not work that way on Windows for whatever reason since technically, it is still only doing playback.
I need to get on a Mac version to see what’s it’s doing, but then again, “logically” it would still be a copy/rewrap as part of the consolidate process – especially for entire takes (and not sub-spans of files). I remember doing it once as a transcode during beta, and while it “fast”, it was decoding and encoding from and to the same codec. But I will test and get to the bottom of this. The Avid website didn’t offer much detail on this specific process.
Michael
Michael Phillips
John Pale
February 26, 2012 at 8:05 pmJust tested on a Mac. Here’s how it works.
Pro Res media linked as AMA does not Consolidate…you get an error message telling you that you need to transcode. It will not re-wrap as MXF.
ProRes media imported into Avid as Pro Res MXF will Consolidate…no need to transcode.
Have not tried with tape media captured as Pro Res, but I would guess it would be the same as imported media.
Michael Phillips
February 26, 2012 at 8:13 pmThanks John. The question now is what where the times associated with either method? Was one fast than the other? Did the import process say “fast import” while importing? And if so, how did that compare to the transcode process?
Or another test; with AMA/transcode. Select the same codec as the source and time it, then select a different codec and time it. What are the times between those two? This will indicate whether it is a straight copy, or a decode + re-encode process is happening.
Michael
Michael Phillips
